I am creating this new thread to get some help on the inline thermostat housing.
Background:
I got engine code P0128 for thermostat malfunction. I ordered a thermostat and installed it but I had leakage problems. I agin removed the whole intake manifold and
- deleted the thermostat,
- put stock housing back in place and made sure it doesn't leak
- Bought and installed inline thermostat housing (Meziere WN0072) and installed right next to the other end of stock housing. I installed the inline housing here (marked in red). Is that the right location?
- Used Autozone 77 degrees Celsius thermostat. Drilled two 3/16" holes 180 degrees to each other on the outer ring.
Problem is, the housing and coolant around it just doesn't get hot enough for thermostat to open while engine coolant temperature shoots more than 210. I think Coolant temperature will go even higher but I didn't want to risk it. I used Torque app to get coolant temperature reading.
Upper radiator hose is very hot to touch and lower not much if any.
Infrared temperature of lower hose 110, inline housing 130, stock housing 137, upper hose 165, and coolant temp from torque app 210.
I am lost here. I did the whole air bleeding to make sure there is no trapped air. I also tried without the thermostat in the housing and coolant flows fine. Unfortunately it keeps coolant temperatures around 140 degrees farenheight and would be equivalent to thermostat stuck open, problem I started to begin with.
Background:
