Short of jacking up the rear, How can I tell if I have an LSD on my 2001 Trooper 4x4?
does that mean you have Limited slip?do a burn out in the rain and see if both tires spin
I know in 99 that manual Troopers, of which there were a few, had a regular transfer case. All of the automatics had the TOD transfer case.J-dawg said:datrupr, is yours an automatic or a manual? I think TOD was an option for manual-tranny equipped 98-99 4x4 Troopers, and all auto 4x4s got TOD. Huh, maybe that merits a rear window sticker ... "Got TOD?"![]()
jason, you want to make absolutely sure when you go to add or change out the dif gear oil because they are different for open and ls differentals.ebacherville said:...
SO the moral of the story is the plate may not say it , just test it ,, youll know pretty easy if you have one..
My truck is a 1992 trooper just so you know, wikipedia says all 1992 and up troopers have limited slip diffs.. dont know if thats right or not ..
Mine did ... ME HAPPY
Jason
you might want to consider one of those tests in one or two of the posts above that have the car jacked up and check it that way.The main advantage of a limited slip differential is found by considering the case of a standard (or "open") differential where one wheel has no contact with the ground at all. In such a case, the contacting wheel will remain stationary, and the non-contacting wheel will rotate at twice its intended velocity â€" the torque transmitted will be zero and the vehicle will remain stationary. In everyday use on typical roads, such a situation is very unlikely, and so a normal differential suffices. For more demanding use however, such as driving off-road, or for high performance vehicles, such a state of affairs is undesirable, and the LSD can be employed to deal with it. By limiting the velocity difference between a pair of driven wheels, useful torque can be transmitted as long as there is some friction available on at least one of the wheels.
What about the wheel on the gravel, was that one spinning?ebacherville said:sure enough the wheel on the tar was spinning.. LIMITED SLIP DIFF YES !!!
Being that you have a Trooper, you don’t have a cover on your axle. You will have to pull the axles out and remove the third member to see what’s inside.ebacherville said:If I change oil in the diff I will pull the cover and look visually to make sure it is one but Im surte it is already..
You remove the 3rd member which is the part that bolts to the drive shaft side of the diff. Pretty common for japanese axles.ebacherville said:No dif cover!.. How the heck do you change the gears?
i'm lost here......are we talking about a dana 44 rear or a Isuzu 12 bolt??? thought the isuzu 12 bolt was discontinued on the 94 Amigos and 95 pups. Thought everything from there on out was either a dana 44 or Gm 10 bolt (hombre)...if its a Dana 44 rear, it has a diff cover, but no drain plug.... I blew up a Dana 44 ONCE from some idiot pulling an illegal u trun infront of me and my stupidity of down shifting from 3rd to 1st and locking the rear up, the 31s ended up breaking a tooth off the spider gear and causing a ship load of mess inside, should have just hit the idiot, and pointed to the NO U TURN sign that i would have pushed him into..... (big problem at this road for illegal u turns, for this reason) hee hee....ok im done2000Trooper said:Here is a picture of the rear 12 bolt (modified 1998-2002) differential, yours being a 12 bolt, should look the same just slightly smaller:
Here is a picture of it broken down:
So to look that the inside you would have to pull out the axle shafts (1) {also the drive shaft} , remove the bolts (2) and pull out the third member (3).
Hope that clarifies it a little bit
The initial post was for a 1992 Trooper... so we are talking about the Isuzu 12 Bolt. The only picture I had available to show was the modified 12-bolt that came on the 98+ Troopers.lowzone said:i'm lost here......are we talking about a dana 44 rear or a Isuzu 12 bolt???
