Fuel line where do you go?
445 views 2 replies 2 participants last post by  mwdrifter86
#1 ·
I recently picked up a 91 pickup with 2.6 I-tec. The truck was partially disassembled and what was hooked up was wrong and the truck would not run.
My question is: Where does the fuel line on the back of the manifold go to? It comes off the fuel rail, and a short rubber hose with a heat shield goes to a metal tube that is bolted to the manifold, then where?
Also where does the large hose on the canister go to? The vacuum diagram that is on the underside of the hood shows it going to the bottom side of the manifold, but i cant figure out where exactly.
Thanks in advance for your help.
