Thanks Buster. I know that the #6 coil assembly is shorter on the 3.2L. Are you sure that is the case for the 3.5DI? Unfortunately, I had already reassembled it before I saw your message, but while I had it torn apart, I took the coils and plugs to the shop that did the work and the mechanic adamantly opposed the notion that he may have missed changing #6. When I pointed out the differences between it and the other 5 plugs and compared it with the old Denso iridium plug from my Chevy, they couldn't explain it. However, they offered to take a look at it if I brought it in - which I did today. They did a compression check on all of the cylinders and said that #6 was only reading around 90 psi while the others were all around 125 and suggested that could be the cause of the fouled plug. They went ahead and replaced the #6 plug so I suppose we will know for sure in a couple of months if the lower compression is the cause of the different looking plug. The P0300 and P0301 codes have disappeared for now since I had the battery disconnected for so long. They offered to scan it again if it came back on anytime soon.
