I have heard various definitions of both "blueprinting" and "balancing" an engine and thought I would add to my confussion by asking for your definitions here on the planet :? .
Here is my understanding: (which may be way off base)
Blueprinting is using the optimum measurement when machining parts for performance and durability as opposed to just keeping the measurements within the "tolerable" range. Curious who determines that perfect spec. I would assume Isuzu engineers had dimensions for a perfect "on-spec" engine in in addition to the tolleration range needed for mass production? Did they publish those in the shop manual? (Don't have one yet so i couldn't check.)
Balancing is making sure related parts are within the manufacturers tollerable range as well as matched in weight. But, not necessarily the perfect "on-spec" measurement.
Which would mean a "blueprinted" engine is also "balanced" BUT a "balanced" engine is not necessarily "blueprinted". Am I way off on these? It also seems a "blueprinted" engine is a ton of work so cost prohibitive for my current 2.6 rebuild
Let the education begin...... :bom:
