Hi,
I decided to take my trooper in to have the valve cover gaskets replaced and the egr passage cleaned and the egr replaced. Now my trooper intermittently stalls when I stop. It doesn't choke or try to keep going it's like someone turns off the switch. When it is in this stalling mode I have to keep one foot on the gas and one on the brake to keep it from stalling. It pumps out black smoke out of the tail pipe and accelerates very roughly until it reaches 15 or so mph. My check engine light came on and the code was P0101 MAF or VAF CKT Range/Perf. I bought a used MAF and replaced it but it still does the same thing. I took it back to the mechanic but he insists it's not anything he did when he did the repairs.
I changed the plugs with the required NiponDensos and it ran great for about an hour. I thought I fixed it. Then it sat over night and stalled the next morning within the first couple minutes driving. Then after reaching my destination it was running fine. Also when I crank it first thing in the morning it doesn't idle like it did before. It used to idle for 10 seconds or so, depending on how chilly it is, at about 11 - 13 hundred rpm. Now it idles at about 6 no matter what the weather is. I've replaced some of the vacuum hoses and have been disconnecting the battery and reconnecting. I'm about at a loss and am near the point of going into the dealer with this. I really don't want to do that. Any help would be appreciated.
Thanks,
--Michael
Thanks,
--Michael
