90 Pickup diagram
1.2K views 3 replies 3 participants last post by  bonez30884
#1 ·
I could really use a wiring diagram for this truck. There is a short in my dash lights. Also my fuel gauge and temp gauge don't work. Fuel gauge moves a little but only goes up maybe to a 1/4 tank. Any help is much appreciated
#2 ·
When I had a '94 Amigo, the same factory service manual covered both the Amigo and Pickup. I no longer have the Amigo or the manual. But that might broaden the options for getting help.
Also, if you're not popping fuses or catching on fire, you probably don't have a short. It's probably one or more bad connections or broken wires.
Jack
#3 ·
Agree, a short will usually blow the fuse to protect the wire or component. You probably have 2 separate problems. The fuel sender in the tank for the gauge would be suspect. And as for the dash lights, I would take a look at the switch first. Does moving the dimmer from dim to bright have any effect on the lights?
