Does anyone know what the thread pitch is on the exhaust manifold studs for a 2002 Isuzu with the 3.5 engine is? I have stripped one of them out and need to repair it with a thread chaser. I know its a 12mm stud just need the thread pitch.
Why would the nut be different than the stud? Thanks for the info but I don't understand that. I have a thread chaser for a 12mm 1.5 and 1.75 but not a 1.25. Replacing the stud is not an option, I can't get it out. Any suggestions??Buster28 said:Stud M12 X 1.5 X 46.6 (6 Each required) Isuzu/Honda part # 8-97115-132-0
The 1.5mm thread is for the manifold side because the nut side is 1.25mm
Nut , Stud
12mm X 1.25mm (6 Each required) Isuzu/Honda part # 8-97170-524-1
Ok I see what you are saying now. I need the pipe side which is the nut side, Well just wasted 22 bucks on a thread chaser set that doesn't have what I need. Thanks again.Buster28 said:Most fine thread nuts and bolts on Isuzu trucks are 1.25mm. The exhaust stud has two different thread pitches 1.5 on the manifold side and 1.25 on the pipe side.
These nuts are less expensive:campbell8300 said:Thank you to B28 for those part numbers. I'm in a similar situation and weighing options. I've got 3/6 good studs and no nuts. Going to Honda Parts or Isuzu is running $60+. Ouch. Are there any other less expensive sources? I hate to say it but I'm also debating removing all studs, drill, helicoil, and going with inch GR8 hardware. ??? Any thoughts?
A simpler option I've thought of is just using an M12-1.5x40 bolt. Advance Auto Parts has those. 6 would be$25. I could probably get them even cheaper at a bolt supply company. I guess that opens the stud v bolt debate.
I don't have a stud available to check the thread pitch, what is the pitch on the nuts you removed?campbell8300 said:Could the studs be M12-1.25 manifold side and M12-1.5 nut side?
