I noticed the slight smell of coolant the other day and started to look around. I found that my overflow tank was near the min line so I knew something was up. I started pooking around underneath and sure enough I found a few drops of coolant on the passenger side of the oil pan. To give you a better idea of where this is, when it falls off of the oil pan it lands on the stearing rack. I can not find the source of this leak. The crank is completly dry so I do not think it is coming from my water pump. Which was replaced about 9 months ago by the way.
Does anyone have any other ideas as to where it might be coming from? Is there a drain plug on the block anywhere near this location?
