Torque on oil pan to engine 1990 2.6L?
Postby thrombolite » Thu Apr 29, 2021 5:41 pm
Hi folks,
Rebuilding a 2.6L 1990 Trooper. For attaching the oil pan to the engine (not the final cover), how much torque? My rebuild kit has the thick rubber gasket so it is funky. Too much torque and it splooges out. Suggestions? I will use RTV liberally as well.
Thanks, Russell
thrombolite
Re: Torque on oil pan to engine 1990 2.6L?
Postby Tentin » Thu Apr 29, 2021 6:04 pm
Here's the specs from the factory service manual
1995 Isuzu Pickup 4WD aka Suzie Q. 3" lift, 32" A/T's
1998 Isuzu Amigo 4WD aka Smeagol The Amigo. 2" Lift, 31" A/T's
Tentin
Have thanks: 27 times
Postby thrombolite » Thu Apr 29, 2021 6:30 pm
Thanks but I think I am saying it wrong. It is not the outer most "pan" with the drain plug, but the casing that is between the pan and the block. All other engines I have worked on have the pan against the block, not a two piece system.
I did see the unmeasureable tiny torque. Is that what folks do in practice? Do you use any Loctite to ensure the bolts don't come out?
This is my first Trooper rebuild so I appreciate the newby advice. And thank you for the factory image.
Russell
thrombolite
Postby Tentin » Thu Apr 29, 2021 6:53 pm
I *think* we are talking about the same thing. #12 in this image?
For this post the author Tentin was thanked by:
thrombolite
Tentin
Postby Tentin » Thu Apr 29, 2021 6:55 pm
Also here's a link to the factory service manual download if you don't have it already
https://www.dropbox.com/s/5a0yrtmejuqi2 ... l.pdf?dl=0
thrombolite
Tentin
Postby thrombolite » Thu Apr 29, 2021 8:09 pm
Thank you for your patience and, yes, you are correct. The "Dot" looked like a plug. Appreciate it!
thrombolite
Users browsing this forum: Google [Bot] and 10 guests
