Trooper radiator sourcing
Postby skydawg » Fri Apr 02, 2021 3:03 am
1990 Trooper V6 2.8L radiator question: Need a new radiator and aftermarket is scarce for a V6 model....put an aluminum in 3 years ago and already leaking so trying to source a brass model. Problem is aftermarket units are readily available for the non V6 engine models and all list it only applicable for the 4 cylinder, BUT the Original Isuzu parts diagrams online list same part number ( 8944595532) for both the 4 and V6.
Is there a difference in the radiators between engines?
skydawg
Re: Trooper radiator sourcing
Postby skydawg » Sat May 08, 2021 7:22 pm
It seems the radiator for a V6 is same for isuzu engine if it's manual transmission. It's confusing as most aftermarket s have different part numbers
skydawg
Postby giusedtobe » Sat May 08, 2021 9:21 pm
skydawg wrote:It seems the radiator for a V6 is same for isuzu engine if it's manual transmission. It's confusing as most aftermarket s have different part numbers
If you mean its the same as the 2.6 4 cylinder then I got mine from Summit Racing for ~$175. Works like a charm.
giusedtobe
Has thanked: 29 times
Have thanks: 33 times
Postby gruff54 » Sun May 09, 2021 7:19 am
V-6 manual uses the same radiator as the V-6 auto? Or the V-6 manual is the same as the I-4 manual?
Mike
'88 Trooper 2.6L 5 spd
'89 Trooper 2.6L 5 spd
gruff54
Has thanked: 44 times
Have thanks: 85 times
Postby Jake.Werecat » Sun May 09, 2021 11:12 am
The latter, 4 cylinder manual and V6 manual use the same radiator. Models with automatic transmission use different radiator, as they need to have an additional section for cooling down hydraulic fluid.
Isuzu Trooper 3.1D 1997
Toyota 4-Runner 3.0V6 1991
Jake.Werecat
Postby gruff54 » Sun May 09, 2021 12:33 pm
Jake.Werecat wrote:Models with automatic transmission use different radiator, as they need to have an additional section for cooling down hydraulic fluid.
Figured that. Main reason I asked is I'd have thought the 4 cyl and 6 cyl would have had different inlet and outlet positions?
Mike
gruff54
Postby giusedtobe » Sun May 09, 2021 6:06 pm
Mike
That makes sense. The aftermarket one I bought for mine has the pipes for a transmission cooler as well.
giusedtobe
Postby JJ_Design » Tue May 25, 2021 1:50 pm
1ST GEN TROOPER RADIATOR,
I know this is an old thread but maybe someone here still needs the Radiator
Follow Ebay Link Below, it is not cheap but looks OEM
https://www.ebay.com/itm/312958479536
First Isuzu - 96 Black Trooper w/ 5 speed manual - Sold in 2018
Currently driving 97 Red & Gold Trooper w/ 5 speed manual
JJ_Design
Users browsing this forum: Google [Bot] and 10 guests
