Easy alternator upgrade
Postby dieslsmoke » Wed Jan 18, 2012 10:12 pm
For those of us with 60 or 70 amp alternators, I just installed unit from 99-02 Trooper (100 amp I believe). It is a much beefier unit and it bolted in the same brackets and used the same length belt (just use the inner 4 grooves on the pulley). I got mine from a local auto recycler for $45 with the electrical connector. I cut off the old plug ,soldered the new one on, and was back on the road in about 45 min. The wires were even the same colors.
Every normal man must be tempted at times to spit upon his hands, hoist the black flag and begin slitting throats.
H.L. Mencken
{SOLD}
92 Trooper S
230k,mi stock
w/custom PS pressure line & 02 Trooper alternator conversion
2000 Rodeo wheels & tires
For this post the author dieslsmoke was thanked by:
Tad
dieslsmoke
Re: Easy alternator upgrade
Postby Buster28 » Thu Jan 19, 2012 3:20 pm
The 99-02 Trooper unit is a 90 Amp Denso
Have thanks: 1216 times
Postby pmat » Thu Jan 19, 2012 10:57 pm
I already did this, definitley a good upgrade. Handles my 1700 watt system and 6 auxilary lights no problem.
-95 Trooper, 3.2 sohc, 5 spd. 6" lift, RIP :(
- 91 BMW E30 318IS
pmat
Postby Wingnut2840 » Tue Feb 07, 2012 3:33 pm
Would this work on a '01 3.2L?
If the women don't find you handsome, they better find you handy!
Wingnut2840
Postby Buster28 » Tue Feb 07, 2012 5:30 pm
A 2001 Rodeo Sport already has a 90 amp alternator.
Postby twilson » Thu Feb 09, 2012 11:30 am
I have the stock 90 Amp Denso alternator on my 02 trooper and have not had one issue with it. I'm actually surprised. I have a lot of accessories wired up including a powerful radio, 2 amps, HID fog lights, HID head lights, under glow lights, floor lights, cb radio , none of these items use a lot of power but the alternator has been very good to me.
-Tyler
02 Trooper Debagged, 5 Speed ,210k,
Throw Out Berring / Clutch @ 77k & again at 147k -
Rebuilt trans around 90k - Isuzu Engine Replaced Under Warranty 77k Miles - LS wheels, Running Boards(removed), CB Radio
MagnaFlow Catback Exaust, 20% Front 5% Rear Tint, Black Gloss Painted LS Wheels, Tinted Tail Lights, Alpine / Kenwood / Pioneer / Full Sound System, 1 12'' Kenwood sub, RAM Grille Guard , Nilight LED Fog / Off Road Lights, 52 Inch Light bar, Old Man EMU Shocks & Springs
PICTURES
MY RIDE
twilson
Has thanked: 32 times
Have thanks: 9 times
Postby batvette » Thu Feb 16, 2012 3:24 pm
anyone know if this is a direct fit for an early 95 passport 3.2? This has the 60 amp alternator and it struggles with my stereo and any accessories, can't really leave the turn signal on.
1995 Passport V-6 2wd 5spd.
Solar powered ventilation & sound system w/custom kickpods and 15's:
http://s353.beta.photobucket.com/user/batvette/library/passportstereo
batvette
Have thanks: 20 times
Postby dieslsmoke » Sat Feb 18, 2012 8:11 pm
I believe the trooper and rodeo use the same part, so it should work. Beware, reman units are REALLY expensive, that's why I got mine used.
H.L. Mencken
{SOLD}
92 Trooper S
230k,mi stock
dieslsmoke
Postby Med!c » Thu Feb 23, 2012 12:25 pm
the only thing I'd watch out for are the plugs. I needed a new alternator and I pulled the alternator off another 2nd gen rodeo and the plugs were different. Same thing again. In the end I had to just take a pic of the plug and ask jerry to just end me the right alternator. I was tired of pulling the wrong alternators. lol.
00' Trooper 4x4- V6 3.5L
5-Speed Manual Aisin AR-5
Isuzu 12-Bolt Modified LSD
Isuzu 10-Bolt Aussie Locked
BGF AT T/A KO 285/75/16
Miss my old rodeo.
98-02 Isuzu Workshop Manual: Link
Med!c
Have thanks: 87 times
Postby cwmoser » Thu Feb 23, 2012 6:40 pm
How much of a PITA is it to remove the Alternator on a 2002-1998 Trooper?
Carl
cwmoser
Have thanks: 13 times
Postby Med!c » Fri Feb 24, 2012 2:03 am
cwmoser wrote:How much of a PITA is it to remove the Alternator on a 2002-1998 Trooper?
Carl
pretty easy.
Miss my old rodeo.
Med!c
Postby Kable » Sat Mar 03, 2012 9:09 pm
batvette wrote:anyone know if this is a direct fit for an early 95 passport 3.2? This has the 60 amp alternator and it struggles with my stereo and any accessories, can't really leave the turn signal on.
If it struggles then you might want to get rid of that pos
Kable
Have thanks: 8 times
Postby Tad » Sat Mar 03, 2012 10:17 pm
There's no need for that kind of comment.
-Tad
[email protected]
https://www.planetisuzoo.com
1999 Rodeo - rebuilt DD
Tad
Site Admin
Has thanked: 122 times
Have thanks: 98 times
Postby ZuBrew » Tue Mar 06, 2012 6:42 pm
:laughing6: LOL
Basinga!
You know kable, he was just referring to your belts being pos if they are stretching and not working properly. He meant no disrespect to you or your ride but was just trying to help you with your problem. We are all friends here trying to help one another. If I asked a friend to help me with a problematic car part and he told me to throw that pos away and buy oem. I wouldn't be offended. So is it still squeeling?
1999 Honda Passport
2WD / OME 913s / 31X10.5X15 / Gabriel Ultras - SOLD
1996 Acura SLX
G80 / OME 919s / 31X10.5X15 BFG / Aisin Hubs - RIP
1994 FZJ80
CDL w/7Pin Mod / OME Med / 285/75/16 AT
ZuBrew
Have thanks: 23 times
Postby festerfm » Wed Mar 28, 2012 9:37 am
i just was down at autozone comparing the alternators for my 97 rodeo 3.2, a 99 rodeo 3.2, 97 passport 3.2, and the 2000+ trooper 3.5. they are all the same size and would bolt up fine, however, the connectors are different. the 97 rodeo/passport looked like they had 4 pin connectors as did the trooper. but the 99 rodeo only had a 2 pin connector.. it's too bad someone couldnt make a plug & play adapter to go from the rodeo 4 pin to the trooper 4 pin... i may look into doin this next time i am at the junk yard. i too have a set of fog lights on the grill, cb radio, a pair of subs and an amp. seems like i have to choose between my rear defrost, fog lights, or radio. cuz all of them at once, and my volt gauge goes under 12...
this is it... for now anyways
<a><img></a>
festerfm
Postby dieslsmoke » Wed Mar 28, 2012 9:51 am
There are multiple pins but only 2 wires are used, white/green, and black if memory serves. Some used 3 wires but the pink is tied into the white/green I believe (have to check the schematic).
H.L. Mencken
{SOLD}
92 Trooper S
230k,mi stock
dieslsmoke
Postby dustinGERSTEL » Thu Jan 23, 2014 7:50 pm
I have a 2002 Rodeo LS and the alternator has fried two times now. The first time was due to ,e taking the Optima Yellow Top out of my wrangler and put it in the Rodeo. Now I don't know what it is. I'm as,king when they replaced it, it was with a low output replacement. I have a 1000 watt sub and HID headlights and I'm assuming that's the cause. Is there a certain year Rodeo or Trooper I should be looking for when I go to the scrapyard tomorrow?
dustinGERSTEL
Postby nasty610 » Sat Jan 25, 2014 11:34 am
For those of you running upgraded stereos, lots of lights or a winch Tad did a 180 amp Alternator upgrade on his rig. He was even nice enough to do a How-to write up and post it on the main page. Here's the link: http://www.planetisuzu.com/articles.htm?id=99&180_Amp_Alternator_on_the_Isuzu_3.2
1996 Isuzu Trooper Base model
Front t-bar crank, Rear lifted with 1st gen Grand Cherokee Coils, Cooper Discovery AT3 265/75R16
1991 Trooper Base Model
HD Sway-a-Way torsion bars, Sweet Camo Paint(adds 50 hp), Snowflakes w/ Firestone Destination LE2 265/75r16
Lift Coil Spring Options
Add-a-Leaf kits and Part Numbers
Longer Shocks for your Lifted Isuzu
nasty610
Has thanked: 23 times
Have thanks: 241 times
Postby IsuzuGeek » Sat Jan 25, 2014 3:09 pm
Anyone know if there is an easy upgrade for 1st gens with a 2.6? I want to run dual batteries and I would like a better alternator to juice everything up.
Bart
IsuzuGeek
Have thanks: 200 times
Postby Tad » Sat Jan 25, 2014 5:07 pm
I did a high-amp one on my 2.6. I think there is a thread under my name about it. If I were doing it again I would just get one of the "kits" off of Ebay to start. It will end up much cheaper. You may need a small relay to turn on the engine relay (basically a 4v coil relay to switch 12v to the engine relay coil) because of the differences between the way the stock one works and how most alternators work.
http://www.ebay.com/itm/140-AMP-CS130-A ... 31&vxp=mtr
-Tad
[email protected]
Tad
Site Admin
Postby nasty610 » Sat Jan 25, 2014 5:24 pm
IsuzuGeek wrote:Anyone know if there is an easy upgrade for 1st gens with a 2.6? I want to run dual batteries and I would like a better alternator to juice everything up.
Bart
Stock you have a Hitachi LR150-718 that is rated at 50 amps. It's a little confusing because the LR160-718 is listed for the same application and it produces 60 amps. Both use a 350 plug, rotates CW, 175mm distance between mounting ears and the pulley is 72mm OD x 17mm V-channel(Pulley class V1). This alternator was used from 1988-95 on all the 4 cylinders.
The 1995 Nissan Pathfinder and 1995-96 Pickup use a Hitachi LR170-745. It uses a 300 plug, rotates CW, 175mm distance between mounting ears and the pulley class is V1. So on paper it looks like you could pull one of these from the junk yard and get a 70 amp alternator with the only mod being a little wiring. I'm not sure it would be worth it though for 10-20 extra amps of power. There is a High Output version made by Mean Green, P/N MG11353, which is rated at 180 amps but it costs around $379.99+ shipping. The
If you don't mind spending some time in a junk yard you could always make your self a 175mm "template" and walk around checking for fitment on various alternators. Anything over 175mm will work, you'll just have to make a spacer to account for the additional distance. I would check the various Nissan's the use the 2.4l and any version of the VGxx series engine since they all use a similar mount.
In my search for IsuzuGeek I stumbled across this page: http://www.maniacelectricmotors.com/hiouispeal.html where they list a 180amp alternator for 92-95 Troopers and Rodeo/Amigos.
Here's a random link that will very useful if you decide to rebuild an alternator or use the kit that Tad listed. http://www.pirate4x4.com/tech/billavista/Wiring/Part2/
nasty610
Postby mdocod » Thu Dec 22, 2016 6:30 pm
Bump for an old goody thread here that I recently referenced as a starting point for an alternator upgrade.
My 95.0 3.2L Rodeo was just upgraded to a 90A alternator from a 2001 Trooper. Purchased reman from Advance Auto (carquest brand). Had a good friend help out. He was able to use a DMM to identify which pins were which. Both systems are 3-pin + power. There's an ignition line, a voltage sense line, and a lamp line. Once identified the swap is fairly straight forward. The alternator bolts right up, the wider/larger pulley was fine. Plenty of play in the adjuster to use it. Doesn't seem to need the pulley swapped. The larger pulley is still delivering great power at idle RPM.
95.0 rodeo, 3" lift, trooper front suspension/axles/tie-rods, 1.25" diff drop, terra-low 3:1, Warn premium manual hubs, custom rear drive-shaft, 235/85-16 Duratrack, ~240 billion miles and counting,
mdocod
Postby QuantumRift » Fri Dec 23, 2016 2:32 am
IF you want to tinker, pick up a junked alternator. A rebuild kit and bearing is cheap, and takes a couple hours of time...it's a fulfilling way to spend an afternoon...heck, generally people will GIVE you a scrap alternator..90 amp, etc.
"If Opportunity knocks and he's not at home, Opportunity waits."
"Find out what it is in life that you don't do well, then don't do that thing."
1990 Isuzu LS SpaceCab 4x4 (Japanese-built, September 1989)
226,000 miles original, unrebuilt engine.
K&N Air Filter
2.6 L 4ZE1 engine, 5-spd manual
Monroe Sensa-track Load Adjusting Shocks (rear)
Monroe OE Spectrum Shocks (front)
MagnaFlow Muffler & Cat Converter
Akebono ProACT Ultra-Premium Ceramic Brake Pads (front)
Wagner Thermoquiet Ceramic Brake Pads (rear)
Owned since 15 miles. Bought new Honolulu, HI in Oct '89.
Original sticker price: $15,000.
QuantumRift
Has thanked: 27 times
Have thanks: 112 times
Postby Dudebra84 » Wed Aug 19, 2020 8:56 pm
i know this is an older post but i'm wondering if anyone could shed some light and help me by telling me how to wire this thing up
99 trooper alternator into a 97 3.2 rodeo any help would be great
ive got the trooper alternator, rebuilt it and i have the connector
help me please guys
Dudebra84
Postby Buster28 » Thu Aug 20, 2020 3:54 am
Dudebra84 wrote:i know this is an older post but i'm wondering if anyone could shed some light and help me by telling me how to wire this thing up
help me please guys
Does the 97 Rodeo alternator connector wiring harness have 4 or 3 wires?
What are the color codes of the wires?
Users browsing this forum: No registered users and 8 guests
