93rodeoTpS wrote:how long do u-joints typically last - the ones on this truck were replaced in '04
They should be fine, the ones on my truck are the factory ones with 195,000 miles on them and they're still fine.
jallantaylor wrote:(3) what physical force makes the clunk sound? - as I understand it - the slip yoke is designed to slide in and out when the suspension is moving up and down - so why does it clunk when you stop or go? (unless your shocks are junk) (4) it feels that upon stopping, a rotating mass preciptates the clunk - as in, something else stops after the vehicle stops, and same with hitting the gas. it turns (rotating mass) and clunks to engage the driving process.
I am not a mechanic, but tinker a bit for fun. this whole issue is nothing but annoying. any elaboration, alternatives, etc would be appreciated.
Tad wrote:Yours is easy. It already has a grease zerk.
Tad
radare wrote:I can’t believe this topic is 15 years old!
txamigo wrote:I am replacing the boot as well, and using a Dana 211916X - bought it from Northern Drivetrain for about $12.50
