Wiring Fault - Central Locking Circuit - Isuzu Rodeo
Postby Father Ted » Tue Apr 06, 2021 2:43 pm
Hi,
I've got an issue with the wiring in a Isuzu Rodeo Denver (2015) which I believe might be due to a short to earth somewhere on the central locking circuit.
At times the reading lamps illuminate when there is no reason - I believe this is not due to the door switches as the roof light does not illuminate when the reading lights are on - to me this is another indication that it is a fault on the central locking circuit as when you unlock or take keys out of ignition then these reading lights illuminate and when you do the opposite these dim out.
There is also a problem with the central locking when I go to lock the vehicle the alarm chirps about 25 times and then the alarm sounds at full level.
I'm guessing that somewhere there is a bad earth which is causing the lights to illuminate, but I'm unsure how to go about locating the actual problem. Before I take it to an auto electrican what can I do to see if I can narrow down the fault?
Any suggestions as what I need to look at or how to progress the fault finding?
Thanks,
Father Ted
Re: Wiring Fault - Central Locking Circuit - Isuzu Rodeo
Postby Buster28 » Tue Apr 06, 2021 4:33 pm
The last Isuzu Rodeo built and sold in the USA was a 2004, where are you located?
2002 Rodeo Sport 4X4 3.2L V6
2020 Jeep Wrangler 2dr 4x4 3.6L V6
Buster28
4L30E Guru
Have thanks: 1308 times
Postby Father Ted » Tue Apr 06, 2021 5:16 pm
Based in UK - sorry - didn't realise at the time of registering that this was a USA based forum.
Father Ted
Postby Enemigo » Tue Apr 06, 2021 5:24 pm
We have lots of non-USA members, so you can stick around.
1999 Amigo - Sold
1999 Trooper. Mods TBD
For this post the author Enemigo was thanked by:
Father Ted
Enemigo
Has thanked: 4 times
Have thanks: 31 times
Postby Father Ted » Tue Apr 06, 2021 6:50 pm
Thanks - even some general advice on how to go forward with the fault finding at this stage would be appreciated.
Father Ted
