fogs on with brights ***update**
Postby jeffmyers » Sat Feb 27, 2021 6:32 pm
Anyone done this ?
for me would be on my 2001 rodeo , but I read the trooper (2001) yellow ground wire on the fog switch can be given it's own ground so the fogs can come on anytime
I know an aftermarket wiring kit will accomplish this but wanting to make it work on OEM wiring
jeffmyers
Has a Trail Truck
Has thanked: 17 times
Have thanks: 8 times
Re: fogs on with brights
Postby mudoilngears » Sat Feb 27, 2021 9:32 pm
Looks like your info is correct.
Here is the diagram in case it's of any use.
1998 Rodeo LS 4x4 4JB1-TC Diesel Swap, Moog CC247 coils, more mods to come!
Build in progress...
mudoilngears
Has thanked: 19 times
Have thanks: 190 times
Postby jeffmyers » Sun Feb 28, 2021 8:21 pm
Ok got it figured out ....
(at least halfway , still need to power the green indicator when the brights are on) see video...https://www.youtube.com/watch?v=5YYbyUMUzys
To do this mod, remove the pin on the for relay that is normally ground , but shows 12volts when the brights are on (see pic)
Give the relay a dedicated ground there, that is the ground that triggers the fogs when you push the switch.
This prevents that ground from going to 12v when the brights are on.
So next I want to run brights and lows and fogs ...anyone got any idea how to do that ?
For this post the author jeffmyers was thanked by:
HONDEO
jeffmyers
Has a Trail Truck
Users browsing this forum: No registered users and 5 guests
