90 Pickup diagram
90 Pickup diagram
Postby bonez30884 » Mon Dec 14, 2020 2:06 am
I could really use a wiring diagram for this truck. There is a short in my dash lights. Also my fuel gauge and temp gauge don't work. Fuel gauge moves a little but only goes up maybe to a 1/4 tank. Any help is much appreciated
bonez30884
Re: 90 Pickup diagram
Postby JoeIsuzu » Mon Dec 14, 2020 8:08 am
When I had a '94 Amigo, the same factory service manual covered both the Amigo and Pickup. I no longer have the Amigo or the manual. But that might broaden the options for getting help.
Also, if you're not popping fuses or catching on fire, you probably don't have a short. It's probably one or more bad connections or broken wires.
Jack
Original owner, 1983 Isuzu P'up LS Diesel. Engine overhauled by JLEMOND. Ready for new paint now!
1994 Isuzu Amigo 2wd
IsuzuPup.com
"There are no dumb questions"?! Maybe not...
but there are smart ways to ask. Old, but classic:
How To Ask Questions The Smart Way
JoeIsuzu
Has thanked: 123 times
Have thanks: 117 times
Postby itsmehb » Mon Dec 14, 2020 9:27 am
Agree, a short will usually blow the fuse to protect the wire or component. You probably have 2 separate problems. The fuel sender in the tank for the gauge would be suspect. And as for the dash lights, I would take a look at the switch first. Does moving the dimmer from dim to bright have any effect on the lights?
Has thanked: 152 times
Have thanks: 321 times
Postby bonez30884 » Sat Dec 19, 2020 11:35 pm
Turning the dimmer down dims the rest of the lights like my thermostat settings
bonez30884
Users browsing this forum: No registered users and 6 guests
