Fog Lights / Fuse Box
Postby Duntov » Fri Oct 30, 2020 1:44 pm
Hello! I am wrapping up installation of some period correct looking fog lights on my 88 Trooper. The switch needs switched power (so that the lights can't be turned on and left on with no key in ignition,etc.), I was wondering if there is a blank power lead or area that I can tap into somewhere? The PIAA's are on a 30 fuse, so was wondering where I could plug in the main light power lead as well. I don't like the idea of going straight to battery. I see that there is a fog light area in fuse panel, but it's only a 20 or 15 (can't remember).
What has worked for you on this project?
1988 2.6 5-spd Trooper daily driver
1989 2.6 Auto Trooper restoring for kids
https://www.planetisuzoo.com/viewtopic. ... 5&t=145765
Duntov
Re: Fog Lights / Fuse Box
Postby Duntov » Fri Oct 30, 2020 6:18 pm
Figured out to use a spade connector in my unused power window relay area in the fuse panel. It has a switched lead.
Duntov
Postby Oro » Sat Oct 31, 2020 5:51 am
Another option, might be safer, maybe not - I don't know exactly what you did - is an ATO/ATC fuse tap.
Like this:
https://www.amazon.com/Circuit-ATC-Pigg ... B009K6U582
Piggy back fuse tap. I used these to put a trans cooler gauge on my a-pillar; I needed to take-off power from my headlight circuit so it dimmed; also non-interruptible 12v power (for color light memory) straight from battery (different issue).
You may be like "$7 for a fuse tap?" and I would totally agree. This is the first hit the search found. I got like a box of 10 of them for $6 off ebay. Just to illustrate.
1998 Acura SLX. OME 929s and front crank, KYB tubes. Retro'd Aisin manual front hubs.
Home rebuilt 4L30E doing great. Aux cooler and temp gauge. Big thanks on the rebuild to Buster28, Jerry (jlemond), CalG, and others.
Factory(US dealer) side steps and roof/ski rack (Yakima).
Oro
Has thanked: 18 times
Have thanks: 150 times
Postby Duntov » Mon Nov 02, 2020 12:05 pm
I like that idea!
Duntov
Postby ZuCruTrooper2 » Thu Dec 03, 2020 6:28 pm
That 30 amp main lead needs to go to the battery. Pulling that much current off of any random wire in the truck is a really bad idea. You can get your relay/switch control wire anywhere you need as it is very low current, but the high current light wiring needs to straight to battery with a fuse within 12" of the battery. The ground for the lights needs to be a good solid ground point (such as the ground bolt next to the battery box).
ZuCruTrooper2
Have thanks: 7 times
Postby Duntov » Thu Dec 03, 2020 7:31 pm
Yes you are right. I was referring only to the switch. Thanks.
Duntov
Users browsing this forum: No registered users and 5 guests
