cd player is beeping
Postby GoldieTroopa » Sat Jun 13, 2020 10:49 am
Hello!
My stock CD player is beeping four times when I turn the ignition on now. I can't figure out why, maybe the extreme humidity here in the south? :shock: How do I reset it? Thank you in advance!
Jennifer
GoldieTroopa
Re: cd player is beeping
Postby happysailor » Sun Dec 06, 2020 7:22 pm
If it's working I would leave it alone and be happy.
happysailor
Postby GoldieTroopa » Sun Dec 06, 2020 8:05 pm
It's not working.
GoldieTroopa
Postby Guitarbuilder » Thu Dec 10, 2020 2:27 am
Mine has always beeped since I bought it. Every time I turn the ignition on. I assumed it was suppose to do that. My CD player has never worked.
1998 Trooper,3.5, 4x4 automatic
Guitarbuilder
Postby Goauld » Sat Dec 12, 2020 7:17 am
Beeping is an error indicating a stuck cd. Unfortunately the jam is due to damage inside the drive.
2000 Isuzu Rodeo LS 3.2 V6 ; GOLF IV 1.9TDI
Goauld
Have thanks: 8 times
Postby Skeletor » Tue Dec 15, 2020 1:23 pm
Goauld wrote:Beeping is an error indicating a stuck cd. Unfortunately the jam is due to damage inside the drive.
manually pull the cd out....some have a minor pin hole, where you can insert a paper clip, and 'push' it open...others, you'll have to remove the unit, and take it apart...you can locate the model on the WWW, and see what your opinions are
1990 Trooper V6 (sold) 1991 Trooper LS V6, (sold) 1990 Trooper V6, 2006 Pontiac Solstice,(sold) 1966 MG Midget, 1987 Pontiac Fiero GT
Skeletor
Have thanks: 47 times
Postby GoldieTroopa » Mon Jan 11, 2021 2:09 pm
Its the stock player, Isuzu premium compact disc changing 5170. I managed to take console off and pull the CD player out but apparently the wires will not disconnect off of the back of the player. I don't have any problem taking the cd player apart because I have taken computers apart before so I took the face plate off and a computer board off of the front of the player while I had it pulled out. When I peeked inside, where in the world are the CDs kept? LOL I couldn't even see where the other end of the wires were going to disconnect them from the other end. :geek:
GoldieTroopa
Users browsing this forum: No registered users and 8 guests
