2000 ckp sensor location
Postby paul6165 » Tue Apr 27, 2021 10:16 pm
Where is ckp sensor located on 2000 Isuzu 3.2
paul6165
Re: 2000 ckp sensor location
Postby Buster28 » Wed Apr 28, 2021 3:49 am
The Crankshaft Position (CKP) sensor is located on the RH side of the engine block by the motor mount attachment.
Have thanks: 1308 times
Postby paul6165 » Wed Apr 28, 2021 9:00 am
Thanks to everyone for the help this forum is a life saver more info than I would have found any where else. I will keep you advised on what I find to help others.
paul6165
Postby paul6165 » Wed Apr 28, 2021 1:51 pm
Ok removed sensor I am getting 4.9 volt on two wires that doesn't seem correct. The two outside wires looking for wiring dia for crank sensor may be shorted between 2 wires.
paul6165
Postby paul6165 » Wed Apr 28, 2021 8:38 pm
Back to basics 1 wire power 1 ground 1 pulse signal all connected to computer. If I didn't get timing correct I should still get a pulse from crank sensor. This is puzzling the truck was running ok just heat problem so leads me to believe computer and sender are ok. Next step I am going to get some gas in spray bottle spray into intake while cranking see if starts.
paul6165
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 27 guests
