1.9 engine mods?
1.9 engine mods?
Postby Pappawheely » Fri Apr 23, 2021 2:29 am
I am new to isuzu vehicles. I have an 85 trooper with a 1.9 4 cyl. I also have a 1.8 4 cyl from a 79 Luv. I read that you can put a 1.8 head on a 1.9 and get more compression. My question is about pulling the head. I have worked on Datsun L series motors. They have an issue with the timing chain dropping into the block causing you to remove the oil pan. (you have to use a wedge to hold the chain). Is this similar to the 1.9? Is ther a manual or resource somewhare that explains how to r&r the cylinder head?
Pappawheely
Re: 1.9 engine mods?
Postby itsmehb » Fri Apr 23, 2021 12:56 pm
It's been a few years but when doing a valve job on an 85 1.9 I remember ty wrapping the cam gear to the timing chain then just lifting the head straight up off the block. Didn't have any issues putting it back together.
Here's a link to another member's build page on an 84. A complete engine build included in link.
https://www.planetisuzoo.com/viewtopic.php?f=15&t=85764
For this post the author itsmehb was thanked by:
Pappawheely
Has thanked: 152 times
Have thanks: 320 times
Postby DSUZU » Fri Apr 23, 2021 4:31 pm
Wood block may be your best bet. Years back I did a head gasket on a Mazda (323?). It had a OHC and timing chain. I hooked a bungee cord to the cam sprocket (after unbolting it). Hooked the other end to the hood. I lifted the head then managed to keep the tension while I worked the head over the bungee end that had been attached to the hood. Dennis
For this post the author DSUZU was thanked by:
Pappawheely
Has thanked: 284 times
Have thanks: 974 times
Users browsing this forum: JackTrooperTown and 34 guests
