Hi
Interesting discussion, very technical. I’m buying a new gas cap today, if that doesn’t work maybe I’ll do a smoke test if I can find the EVAP access port. P0442 seemed to appear after I pinched the fuel cap cord, maybe the seal was damaged. Car still running great, MPG at near 18, mix of highway and town driving. A lot better than the 14 MPG I was getting when I first posted on Planet Isuzu some months ago. I’ll keep you posted!
I also thought you might be interested that the Isuzu TIS2000 programming station that I bought is back again for sale on eBay, obviously the seller is cloning the system, so goes the claim “last one”. Oh well, I accomplished the fuel sending unit programming on my PCM and the computer will be helpful when I attempt to work on my ABS DTC.
Lastly, is the Painless 60550 GM Gen III Bench Top Programming Pigtail compatible with the later model Isuzu’s like yours? Someone with a 2002 wants their PCM re-programmed. I think the 1998-1999 Amigo’s and Rodeo’s shared the same PCM, then the PCM changed to the 3rd generation from 2000-2008.
https://www.amazon.com/dp/B005AU9880/re ... UTF8&psc=1Thanks,
Debi23
