by Eric B » Mon Dec 07, 2020 12:18 pm
I believe I can flush cut the tube , carefully split it within the raised boss , and collapse it . The boss appears to be about 4 mm thick , and I can tap 12 to 14mm in depth. I may go standard pipe thread ( NPT) but the jump between 1/2" and 3/4" is quite a bit. I could also warm the manifold in the oven - like 200 degress, and freeze a new tube, then press them together. I have access to liquid nitrogen. The cooling system is under pressure , about 14 lbs , not much , but it cannot leak. I own a mill , presses , and have access to a machine shop , but I am wondering if anyone else has completed this repair , rather than simply buying another one .... of which there is a dwindling supply of new ones.
1993 Trooper S 4x4, MUA5 spd, 2 meter Yaesu, iPad nav and topo, dual shocks , Old Man Emu, front Lokka, G80 , Falken 32" x 11.5 on 15's , 6 gal aux fuel , 9.5 gal H20 storage.
