rugged ridge manual hubs like aisin
Postby caccia » Tue Sep 17, 2013 2:25 pm
i've buy a couple manual hubs rugged ridge like looks aisin... in to the package i do no have instruction.
I do not know what I have to tighten the bolts nm, can I use the nm of AISIN? someone knows them?
another question ... I have no seal from the hub and hub carrier original AISIN exist? where I made the arrows
thanks guys
caccia
Super Trooper
Re: rugged ridge manual hubs like aisin
Postby CatFuzz » Tue Sep 17, 2013 7:10 pm
You should be able to use the same torque spec as the Aisin hubs. As for sealing the hubs, some RTV silicone sealer will work just as well as a gasket would.
99 Rodeo, 3.2L Auto, Manual hubs, "Trooper lift".
“I taught constitutional law for ten years. I take the Constitution very seriously. The biggest problems that were facing right now have to do with George Bush trying to bring more and more power into the executive branch and not go through Congress at all, and that’s what I intend to reverse when I’m President of the United States of America.”
-- Then-Sen. Barack Obama in a campaign speech.
ABS and traction control are for people that don't know how to drive.
CatFuzz
Has thanked: 36 times
Have thanks: 135 times
Postby caccia » Wed Sep 18, 2013 7:35 am
I used AISIN torque and damaged a hub ... are equal to see, but unfortunately not the same quality :cry: :cry: :cry:
caccia
Super Trooper
Postby CatFuzz » Wed Sep 18, 2013 7:57 pm
Were the surfaces clean? If there was a bit of gasket stuck on it could be enough to crack the housing when torqued.
CatFuzz
Postby Ruination » Thu Sep 19, 2013 10:25 am
caccia wrote:I used AISIN torque and damaged a hub ... are equal to see, but unfortunately not the same quality :cry: :cry: :cry:
The rugged ridge aisin knock offs are pretty terrible. I got a "tester" set here... chinese junk!
I destroyed both of them with "light" wheeling. I was actually just backing up when the one let go completly. Although I am locked in the front that should not have happened.
I'm curious to know the type of material used to make those and if they are like the chinese made ones I got.
RR hubs are going in the trash next chance I get to put a set of Aisins back on.
1992 Isuzu Pickup S - Bad Weather
2004 Buick Ranier "Bruick" - People Mover
2008 Saturn Sky Redline - Nice Weather
Ruination
Has thanked: 15 times
Have thanks: 64 times
Postby rumblefish » Thu Sep 19, 2013 6:04 pm
Is installation of the AISIN hubs the same as installing Superwinch hubs?
Still looking for a PDF or instructions, but loosing patience with myself.
BTW, I used Gasket-cinch on my Superwinch hubs & no problems at all.
Plowed through muddy water, mud, rain, etc.. & when I took the one apart because I smacked it on a rock, it was still nice & clean & dry inside, except for the necessary lubrication.
rumblefish
Has thanked: 33 times
Postby Gizmo42 » Fri Sep 20, 2013 1:59 am
rumblefish wrote:Is installation of the AISIN hubs the same as installing Superwinch hubs
Pretty much the same. Make sure the hub is in the Free (2wd) position before taking the dial cover off. Bolt the hub body on with the large allen bolts, install the snap ring on the end of the cv shaft, torque large allen bolts to 44 ft lbs, slide dial cover on (should only go in one way, rotate until the groves match up), put in the small dial cover bolts and snug them. Whether you use rtv, paper gasket, or something else to seal them is your choice.
--Dave
For this post the author Gizmo42 was thanked by:
rumblefish
Gizmo42
Have thanks: 137 times
Postby rumblefish » Fri Sep 20, 2013 2:43 am
Thanks much Gizmo42.
rumblefish
Postby caccia » Mon Sep 23, 2013 9:26 am
comparison SUPERWINCH have less current game but the material is weaker. :?
the superwinch body hub is iron, in the rugged ridge is i think alloy... :shock: :shock:
rugged ridge write for the body hubs 45lbs in nm is only 5nm... :roll: :roll: and the cover is 3/4nm...
I am very confused, whether to keep or change to SUPERWINCH rugged ridge ...
what you think?
caccia
Super Trooper
Postby rumblefish » Mon Sep 23, 2013 10:21 am
I recently posted a very similar question & received much appreciated advise. Look up my recent postings. The only reason I ever swapped out my OEM hubs was due to the angle put on the CV joints & boots by cranking up the torsion bars, otherwise I would have left things stock. I knew that any gas mileage improvement would be negligible. I was just trying to save my CV boots. That being said, once I smacked a rock & cracked the driver's side Superwinch hub, I temporarily reinstalled the OEM hub on that side. The passenger side still has the locking hub installed. It did not take long before my new CV axle's boot on the driver's side, was torn open as predicted in many write ups, forums & by hub vendors.
rumblefish
Postby Ruination » Mon Sep 23, 2013 11:39 am
what you think?
I would not depend on them...
This is how mine ended up. This was the lightest my truck had ever been wheeled (usually I beat the crap out of it), but it did have a locker and was in some heavy torque situations. I even have a video of the truck making it to the top of daniel right before the left side grenaded.
(notice the housing cracked/broken in two places, and the cog in the center has stripped out the inside of the housing)
This was the last climb I did before the hub broke. as you can see I was just letting the truck idle and using the gas pedal to keep it from stalling as I drove up in 4 low and 4.77s. (yes this is alot steeper than it looks).
http://www.youtube.com/watch?v=v_M0QfvCGEA
The hub blew at the top when I put it in reverse to turn in between two trees.
Ruination
Postby Ruination » Mon Sep 23, 2013 11:44 am
The way it broke at the top, I was surprised how it did not break here:
http://www.youtube.com/watch?v=hdi39OVpvqY
or here:
http://youtu.be/a_tVKME_jok?t=48s
lol.... in face I don't know how the RR hubs don't blow up as soon as you put them in 4wd!!
Ruination
Postby caccia » Mon Sep 23, 2013 12:31 pm
orrible photo...
my superwich hubs have 7years old nothing problem... i'm very confused :roll:
caccia
Super Trooper
Postby caccia » Mon Sep 23, 2013 12:57 pm
http://www.thetoolhut.com/Torque-Conver ... etric.html
44 ft lbs is to high... i try to to 45nm (33ft lbs) and i damage the body hub material of the hub body of crushes and deforms
caccia
Super Trooper
Postby Ruination » Mon Sep 23, 2013 2:36 pm
caccia wrote:Image
orrible photo...
What is so "orrible" about the picture? Let me translate what you see in the picture a little better.
Again, I stress the point that this is what I consider light wheeling, although with the locker, there is a lot of torque on those parts.
I didn't believe these were that crappy until a friend told me he grenaded his test set on his mitsubishi on gravel before he even got to the technical stuff. He runs 35s although irrelavent.
Ruination
Postby caccia » Mon Sep 23, 2013 2:49 pm
I'm sorry for the horrible picture meant to give the hub .. :oops: not the photo of poor quality
do not really know what to do ... rugged ridge weight is Greater. SUPERWINCH very light!! io have 265/75-16 not arb or other..
caccia
Super Trooper
Postby rumblefish » Mon Sep 23, 2013 4:41 pm
I just got my Aisin hubs in the mail & they are definitely heavier than my Superwinch hubs. Have not installed them yet.
Someone explain me this please.
When I smacked the boulder & cracked my driver's side locking hub, I could still climb up crazy steep & loose inclines, but if I tried to reverse up the same incline, my rear tire(s) would break traction & spin. The fronts were not engaging in reverse. This is with the cracked hub still in place & I could still turn the dial.
rumblefish
Postby Gizmo42 » Tue Sep 24, 2013 12:31 am
caccia wrote:44 ft lbs is to high... i try to to 45nm (33ft lbs) and i damage the body hub material of the hub body of crushes and deforms
They must be really weak then. I've used 44 ft lbs (what Isuzu says to use on those bolts) for the stock flanges, Superwinch hubs, and Aisin hubs with no problems.
Probably just the way the broken parts lined up. Would lock up forward but slip in reverse.
Thankfully when I damaged mine on a rock this is all that happened to it...
Ran then for a few more years that way with the chamber that was punctured filled with rtv. Sold them this year to one of the VX guys for 1/2 what I paid new. He wanted another set for spare parts. Most SW hubs I've seen broken by torque are from vehicles with front lockers, which his has.
--Dave
rumblefish
Gizmo42
Postby caccia » Tue Sep 24, 2013 3:18 pm
is not steel or iron, i think is alloy or similar.. but the total weight is greater than the SUPERWINCH
caccia
Super Trooper
Users browsing this forum: No registered users and 7 guests
