Smog/Air injection system removal?
Re: Smog/Air injection system removal?
Postby Buffalo Bruce » Sat Apr 24, 2021 4:44 pm
Just got an 86 P'up auto 3 speed, getting 36 mpg. That seems pretty good for 3 speed, it needs another gear. My first post.
Buffalo Bruce
Postby Buffalo Bruce » Thu May 27, 2021 12:25 pm
1986 2.3 P'up, How come my carb has no gas/air adjustment screw? Is there a carb to replace it that has one? Thanks
Buffalo Bruce
Postby DSUZU » Thu May 27, 2021 6:10 pm
Buffalo Bruce wrote:1986 2.3 P'up, How come my carb has no gas/air adjustment screw? Is there a carb to replace it that has one? Thanks
It does, it's just blocked by an ''anti tamper" plug. There may be either a solid round plug (about 3/8") or possibly a hole with a dowel through it on the passenger side of the carb base (I had an 87 2.3 Trooper and an 87 Suzuki Samurai and that's what was there for tamper proofing - I just don't remember exactly which was which after 24 years)
The round plug can be removed by CAREFULLY drilling a small hole, threading it, installing a screw and pry out (careful to not drill too deep and damage ide mixture screw). The dowel type requires removing the carb, and possibly the base (or brutality with a small chisel :lol: )
If you are in a non emissions area, a Weber replacement carb with adapter is a possibility, but If I were getting 36 MPG, I'd count my blessings. Dennis
Has thanked: 284 times
Have thanks: 974 times
Postby Buffalo Bruce » Thu May 27, 2021 8:30 pm
I did notice that the spot was plugged, I will drill it out. The glitch will be to get the correct length screw/spring. Thanks
Buffalo Bruce
Postby Enemigo » Thu May 27, 2021 8:48 pm
Use the high school drilling method. Pull out early and often.
Have thanks: 32 times
Users browsing this forum: No registered users and 8 guests
