30-43LE Trans/transfer case.
Postby innocentbystander » Tue Mar 30, 2021 7:10 pm
I am redoing someone else's Isuzu 4JG2/ 30-43LE swap. Original transfer case has passenger side drop and I need driver side drop. I removed original T/C and had to get a rear trans housing from a jeep AW4 to mate a NV/NP231 T/C. (AW4/A340/30-43LE are same trans with various changes) The problem now is the output shaft of this trans is 27 spline and the 231 T/C is 23 spline. It appears that they do not make a 27 spline input shaft for this T/C. Anybody have any suggestions? I could swap the trans output shaft from a AW4 or A340 but would have to confirm it would interchange and then would have to basically rebuild the trans..
innocentbystander
Re: 30-43LE Trans/transfer case.
Postby mudoilngears » Wed Mar 31, 2021 12:39 pm
What are you trying to accomplish that requires a LH output?
1998 Rodeo LS 4x4 4JB1-TC Diesel Swap, Moog CC247 coils, more mods to come!
Build in progress...
mudoilngears
Has thanked: 19 times
Have thanks: 188 times
Postby innocentbystander » Wed Mar 31, 2021 1:08 pm
International Scout
innocentbystander
Postby mudoilngears » Wed Mar 31, 2021 1:37 pm
What you need is a transmission from a second gen Dmax
mudoilngears
Postby Enemigo » Wed Mar 31, 2021 2:56 pm
1999 Amigo - Sold
1999 Trooper. Mods TBD
Enemigo
Has thanked: 4 times
Have thanks: 32 times
Postby innocentbystander » Thu Apr 01, 2021 7:43 am
Thanks, but dont think its going to bolt up to a 4JG2 plus would have to change all the shafts or yokes, I already have the 30-43 that goes to a 4Jg2 so im working backwards from there. I think I have everything mating wise worked out except the spline count.
innocentbystander
Postby mudoilngears » Thu Apr 01, 2021 11:58 am
Yes it will bolt up. All the ā€œ4jā€ series share the same bellhousing pattern.
mudoilngears
Users browsing this forum: No registered users and 5 guests
