Wind Wing rubber replacement
Postby Bob of LA » Tue Jul 14, 2015 1:19 pm
Replacing the rubber is quite a job for a novice, but with the right tools it’s doable - also protecting the paint on the door inside & out with a few layers of tape is a good idea.
The nuts that hold the window on are very hard to get to without a special wrench so I used a socket (standard & deep), three extensions & a ratchet to reach from bottom of the door(access hole).
My rubber was totally petrified, so chipping it out was like an Archaeological dig & took the most time. but once it’s out the rest is pretty straight forward. One trick is to Hot Glue the spring & washers
together, push them onto the window bolt w/ a large socket & hope they hang there while you grab a 10mm socket & nut.
The only other thing I might mention is when removing the part of the rubber that is embedded in the track, it helped to make long diagonal cuts with a box cutter & remove triangular shaped strips..
If i missed anything - let me know
Bob of LA
Re: Wind Wing rubber replacement
Postby wmorrisiii » Sat Aug 15, 2015 2:56 pm
This job is a pia. I've seen a lot of first Gen's that have that diagonal cut right behind the bolt and then sealed back together with RTV, quick and easy. Good for you for doing it the right way!
Willie's 1990 Trooper LS, 2.8L
The Duck Marsh Debutante
Willie's 1987 Trooper LS, 2.3L
The Coonhound
wmorrisiii
Has thanked: 94 times
Have thanks: 203 times
Postby Bob of LA » Sat Aug 15, 2015 9:50 pm
Thanks - I actually thought of doing that, but thought I give it one try before the Micky Mouse approach.
Bob of LA
Postby outofrshell » Sun Aug 16, 2015 11:21 pm
This has nothing to do with the wing window but the idea of using hot glue to hold multiple parts together was a stroke of genius. I just finished a R & R on a 1991 V6 Trooper engine and I put the distributor in on the engine stand !80 Deg. out DUH! so once installed had to pull dist. This requires removing the bolt and clamp in a real tight spot, gluing the bolt and clamp together and then gluing the wobble socket to the bolt head made it possible to get it back together SO A BIG THANKS DAVE
1989 Trooper 2.8/ 3.2 built V6, 5speed
Revolution gears
ARB Rear locker
ARB Front locker
SWAY-AWAY HD TORSION BARS
Self made Longer shackles
1998 Trooper front disc brakes and front seats
Self made HD Tie rods
Self made bumpers and grill guard w/ KC & Hella lights
Self made sliders
Waren VRS 8000 winch set up to use at either end of Trooper
Custom made cargo box w/ full length roll out drawers
31 X 10.50 X 15 Cooper STT Pro on Cragar black steel wheels
outofrshell
Have thanks: 48 times
Postby imamonstertruck » Mon Aug 17, 2015 12:32 pm
Awesome, thanks! This is on my to do list :D
cheers
-Ian :blackeye:
-91 Trooper, 3.4 V6, 5speed, 4.77 gears, 3:1 Revo T-Case Gears, HD tie rods, 3" body lift, 2" suspension lift, 1.5" diff drop, 33x10.5x15 BFG A/T,
Round Eye Swap (JDM marker lamps).
1989 Trooper RS https://forum.planetisuzoo.com/viewtopic.php?f=15&t=81642&p=722882#p722882
Previous Troopers and Build Thread->https://forum.planetisuzoo.com/viewtopic.php?f=15&t=63260
1988 ISUZU TROOPER WORKSHOP MANUAL
"There are only two days in the year that nothing can be done. One is called yesterday and the other is called tomorrow, so today is the right day to love, believe, do and mostly live."~ Dalai Lama
“Unless someone like you cares a whole awful lot, nothing is going to get better. It's not.”Dr.Suess
Aaronmcvay84 wrote:I think with isuzus there is a more mature crowd that realizes the value of their hard work. They keep things.
imamonstertruck
Has thanked: 55 times
Have thanks: 175 times
Postby Bob of LA » Mon Aug 17, 2015 6:00 pm
Good goin...Dave
The one part of the wind wing job that didn't go right was that when I tightened the tensioning nut down all the way down( drivers side) it still won't hold the window open past 40 MPH
Any suggestions ?
Bob of LA
Postby outofrshell » Mon Aug 17, 2015 8:06 pm
Two options: 1- don't drive over 40 MPH 2- More hot glue Seriously tho maybe try to source a new spring from a parts Trooper or add a couple of washers. Dave
Revolution gears
ARB Rear locker
ARB Front locker
Self made sliders
outofrshell
Postby Needlebender » Sun Jul 30, 2017 2:49 am
Where did you find new replacement rubber molding for the wind windows?
Needlebender
