kg4miq wrote:For the 4ZE1 distributor (and possibly for the 4ZD1 as well, I'll have to check), the internal oil seal in the distributor is a NOK 3286, dimensions are: 12.45mm x 22mm x 6mm. This is the same seal Honda Accords used on the F22B1, F23A1, F23A4, and F23A7 engines, FYI.
kg4miq wrote:Quick update: Talked to Jerry yesterday and he brought up a valid point - the gear with the cotter pin is 13 tooth, and can be reassembled 180 degrees out of "normal" position. What this means is that timing your engine will be an exercise in frustration, due to the gear being several degrees out of sync (think: optical wheel, timing pulse, etc) from what it should be. I guess he and I have just been fortunate, in that we've only seen one instance where it was installed incorrectly and became a problem. I told him I would update this thread with the information.
Mark it somehow before disassembly, and be certain to reassemble the gear onto the shaft in the same orientation it was originally.
HTH,
/tim
AWK666 wrote:kg4miq wrote:Quick update: Talked to Jerry yesterday and he brought up a valid point - the gear with the cotter pin is 13 tooth, and can be reassembled 180 degrees out of "normal" position. What this means is that timing your engine will be an exercise in frustration, due to the gear being several degrees out of sync (think: optical wheel, timing pulse, etc) from what it should be. I guess he and I have just been fortunate, in that we've only seen one instance where it was installed incorrectly and became a problem. I told him I would update this thread with the information.
HTH,
/tim
Hi - digging up an old thread yet again - I am in the process of rebuilding my distributor today, I noted that on my 4ZE1 the split pin (cotter pin) is offset on the shaft, so you can only put the 13 tooth gear back on one direction.
Did have a little freak out reading this comment after disassembly, thought id share what I found.
Cheers
Users browsing this forum: The Don and 1 guest
