Anyone rebuilt a distributor?
Postby meathead » Fri Aug 26, 2011 9:29 pm
Has anyone ever taken apart a 2.6 distributor? I was hunting a massive oil leak and found oil running from the distributor cap! It's an internal leak so got to be a seal bad inside the shaft. The epoxy they cover the screws with on the electronic parts is a bear to get off though. Anyone got one of these apart before? I swapped it out with a another 220,000 mile unit for now. I see several have replaced theres, but at $200 thats not happinen anytime soon! Search hasn't turned up much.
Thanks
'89 TrooperII, 2.6 5spd, 33s, welded rear, homemade and cobbled-up. Now .40 over, decked, surfaced, Delta cam, and rebuilt injectors. No one wants to be seen in it, but everyone wants a ride.
meathead
Trail Rider
Have thanks: 5 times
Re: Anyone rebuilt a distributor?
Postby shooter » Fri Aug 26, 2011 9:51 pm
The service manual states the distributor isn't rebuildable. The oil is probably due to the rubber O-ring being defective.
1989 Isuzu Trooper S/ 4WD / 2.6 Litre 4 Cyl 4ZE1 Converted to Weber 32/36 Carb / 5-speed Manual (MUA5) / Warn Premium Hubs / Fancy Radio / Deluxe Intermittent Combination Wiper Switch
I'd rather laugh with the sinners than cry with the saints
Some people are like Slinkies; they are not good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
For this post the author shooter was thanked by:
1948170
shooter
Has thanked: 35 times
Have thanks: 154 times
Postby govno90 » Fri Aug 26, 2011 11:18 pm
shooter;
everything is rebuildable, just maybe not to factory specs. look at all of those cars in Cuba that were built in the late 40s and early 50s. they have no access to new parts, but they obviously make them work somehow.
cheers, john
it's OK for you too!
1990 trooper XS 2.8L auto
currently building 3.4L -(built, but not yet installed) -(installed, but not yet running) -(finally running, but not properly)
govno90
Has thanked: 2 times
Have thanks: 12 times
Postby shooter » Fri Aug 26, 2011 11:54 pm
govno90 wrote:shooter;
cheers, john
That's cool; how you do it?
shooter
Postby meathead » Wed Aug 31, 2011 1:13 pm
Well, aside from the electronics, I don't see why they can't be serviced. A handfull of screws and a punch for the rollpin and they come right apart. One sealed bearing in there and one tiny oil seal. Will be stopping by NAPA on way home to see if they can measure it and find one. That is the smallest oil seal I've ever seen.
meathead
Trail Rider
Postby Selahdoor » Wed Aug 31, 2011 2:05 pm
Caveman has rebuilt one. Sort of.
Look a few posts down on this page. Then pm him, if you want to ask him some questions.
viewtopic.php?p=388487
-Jeff
1988 Trooper LS. 4ZE1. mua5.
Selahdoor
Forum Admin
Has thanked: 99 times
Have thanks: 166 times
Postby meathead » Wed Aug 31, 2011 3:45 pm
Thanks. After driving with the spare dizzy in there, I have another oil leak from somewhere else. It's leaking ALOT, but it's at the rear, right side of engine. I put a repair sleave and new rear main in last summer. Back to hosing it off again. Trying to avoid pulling the trans, but can't find any other source of the leak.
meathead
Trail Rider
Postby kg4miq » Mon Oct 14, 2013 9:40 pm
EDIT: updated with link to seals
https://www.bestpartsonline.com/index.p ... ct_id=1803
Sorry to resurrect the old thread, but I'm in the process of doing this today and thought I'd share.
For the 4ZE1 distributor (and possibly for the 4ZD1 as well, I'll have to check), the internal oil seal in the distributor is a KOK 3286, dimensions are: 12.45mm x 22mm x 6mm. This is the same seal Honda Accords used on the F22B1, F23A1, F23A4, and F23A7 engines, FYI.
Rebuilding these distributors does NOT require disassembly of the crank position sensor (with the potted screws) as someone had mentioned on one of these threads. A bench vise makes rebuilding these distributors so much easier. Clamp the lower shaft gear in the vise to hold the distributor vertically and disassemble from the top down. When you get the cap off, you'll see the thin wafer-like crank position sensor disk. Simply remove the large phillips-head screw in the center of the distributor shaft, and be very careful to not damage or bend the wafer disk as you remove it from the distributor. Underneath the disk you'll see the retainer cover with two screws holding the bearing in place. Under the bearing is the shaft oil seal mentioned above. Turn the distributor on its side and reclamp the cam gear in the vise (below the worm gear teeth - on the smooth portion of the cam gear) with the rolled pin facing up. Now use a punch or allen wrench of about the same size to push the rolled pin out of the cam gear. Once that's done, the cam gear should come off the distributor shaft fairly easily and the shaft should come out of the housing. Reassemble in the reverse order. I'll try and post some pics soon.
How to rebuild a 4ZD1/4ZE1 distributor
Just added a few more Isuzus to the pack.
'91 Trooper II - GM 2.8L V6, 300k, needs engine rebuild
'90 Trooper II - 4ZE1, needs engine rebuild
'91 LS Trooper - "Kylo Ren" - GM 2.8L V6, 159k, running
'92 Pickup - 4ZE1, needs engine rebuild
'92 Pickup - "Blacktail" - 4ZE1, SOLD
'89 SE Trooper - "Vader" - 4ZE1 - 1UZ-FE Lexus V8 swap on hold
'89 Pickup - "Wicket" - 4ZD1
'90 S Trooper - "Nan" - 4ZE1
kg4miq
Has thanked: 23 times
Have thanks: 107 times
Postby wesharris » Mon Jan 13, 2014 10:24 pm
i would love to see those pic.s of this proceedure im gonna have to do something with my dis. and like the OP i cant afford to buy a new one
1990 trooper 2.6 msd6al ignition system msd turned "out to junk" blaster ll coil accel wires iridium NGK plugs 5 speed new head brake rotors and brakes 16" wheels new tires. new axles new clutch,flywheel,clutch master and slave cylinder all new ball joints 95 trooper front seats and turbo coming soon
viewtopic.php?f=15&t=65233
wesharris
Has thanked: 78 times
Have thanks: 28 times
Postby wesharris » Tue Jan 14, 2014 4:18 pm
Anyone???
wesharris
Postby kg4miq » Tue Jan 06, 2015 2:56 pm
Sorry, Wes, for the delay. Just now saw this. I'll try to get those pics updated here soon.
kg4miq
Postby Fox » Fri Jan 16, 2015 2:35 pm
Please do, as I am having massive oil leaks out this as well...
Where did you end up getting that NOK 3286? NAPA carry it by chance?
Thanks for the trouble.
Fox: the official Non-Forum Troll
Have a question? Things I have first hand experience in.
'91 Amigo : fresh 2.6L 4ze1 . Hybrid rhb5 Turbo . Delta 260 camshaft . 59.5" Wide Track & Big brake front suspension . BJ flip&space . Lokka's front/rear . 31" BFG M/T Km2
I machine parts. BJ spacers, EGR plates, Alignment shims, etc.
Fox
Trail Rider
Has thanked: 8 times
Have thanks: 10 times
Postby kg4miq » Fri Jan 16, 2015 5:31 pm
Ebay. Bought a pack of 6. Search for the Honda engines listed above, or NOK 3286. Pics are on another camera, so I'll try to get those uploaded tonight or tomorrow.
kg4miq
Postby kg4miq » Tue Jan 20, 2015 1:41 am
Sorry it took so long, but here are the pics, as promised. Had to locate the correct memory card from the right camera. Hope this helps!
kg4miq was thanked by:
DSUZUgb89amigoMarkB.NVSelahdoortakemehome4LOroadswesharris
kg4miq
Postby kg4miq » Tue Jan 20, 2015 2:27 am
Continued...
In addition, under the wavy washer is also an indexed washer with two tangs which face upward. It sits atop a T-shaped sleeve on the distributor shaft, which can be easily pulled upward prior to removing the distributor electronic sensor module.
The module itself is not rebuildable, but hardly ever goes bad. The lens might get dirty, or the cable might develop a problem, but there is not a lot of trouble with these, ordinarily. If you suspect the module IS defective, try to source a good used one at a junk yard or pick-n-pull.
Do not forget to place the washer here before you reinstall the electronic module.
The best method of removing the inner seal is to flip the housing over and use a long flat-bladed screwdriver inserted down the shaft hole to push the seal out by tapping the screwdriver with a small mallet. This will most likely destroy the seal, so ensure you have a replacement prior to attempting this. NOK 3286 is the part number. Check eBay for the Honda engines listed above ("F22B1 distributor seal").
Once the seal has been replaced, put a light film of grease inside the inner seal before inserting the shaft into the housing during reassembly. The bearing can be replaced at this time, as well, but sadly, I forgot to get a part number for it. Can anyone assist with this?
In order, from top to bottom on the distributor shaft, inside the housing, under the metal plate cover:
1) rotor button sleeve
2) slotted optical disk
3) wavy washer
4) two-tanged index washer (to align the disk)
5) T-sleeve
6) electronic module with three screws
7) small washer sitting atop the inner bearing (two screws hold the bearing in place)
8 ) inner bearing
9) inner seal
Hope this helps!
gb89amigomustanger999Selahdoor
kg4miq
Postby kg4miq » Tue Jan 20, 2015 3:07 am
Could/should this be added to the wiki?
kg4miq
Postby Selahdoor » Tue Jan 20, 2015 3:12 am
kg4miq wrote:Could/should this be added to the wiki?
I HOPE so!!
-Jeff
Selahdoor
Forum Admin
Postby wesharris » Fri Jan 23, 2015 4:35 pm
Thank you, very much for taking the time to make this repair I hope to complete this on my distributor . thanks again
wesharris
Postby mustanger999 » Fri Jan 23, 2015 10:37 pm
This is a very good write-up.
Truth. The pill that everyone wants, but cant seem to swallow.
'93 Trooper RS, 3.2, SOHC head swap, 3" suspension lift, ARB bullbar, 16" Rodeo Flakes, 285/75r16 Corsa A/T,
'89 Trooper RS, 2.6 5spd, Smittybilt rear bumper Sort of build thread
GONE'89 Trooper: 2.6 5spd, Weber 32/36, Round eye swap, 3" body lift, Sliders, Auto-Meter center cluster, Hand throttle. Build thread
SOLD '93 pickup: 2.6 mfi, 4x4, 5spd, Passport Bucket Seats, Intermittent wiper added. Build Thread: forum.planetisuzoo.com/viewtopic.php?f=15&t=72720&p=639130#p639130
mustanger999
Has thanked: 48 times
Have thanks: 82 times
Postby Fox » Sat Jan 24, 2015 12:24 am
I just did mine yesterday. Its a easy process... and the pictures aren't necessary by any means. But its a nice guide to have!
Thanks.
Fox
Trail Rider
Postby DSUZU » Sat Jan 24, 2015 10:27 am
Thanks for taking the time to post this. While I don't have any problems with my dizzy right now, I appreciate your efforts to help others. Dennis
Has thanked: 283 times
Have thanks: 949 times
Postby MarkB.NV » Thu Mar 26, 2015 12:03 am
DSUZU wrote:Thanks for taking the time to post this. While I don't have any problems with my dizzy right now, I appreciate your efforts to help others. Dennis
Ditto - heckuva job schooling your Planet friends on the service steps for the dizzy. Great pics too!!! :D
MarkB.NV,
Black 1989 RS, 2,6 / 5 speed, 149K mi.
Tan 1986 Trooper, 2.6 / 5 speed, 173K mi.
Sold ... White 1984 Trooper, 1.9 / 4 speed
Sold ... Silver 1990 Trooper, 4 cyl, 5 speed
Sold ... Blue 1989 Trooper, 4 cyl, 5 speed
MarkB.NV
Has thanked: 95 times
Have thanks: 148 times
Postby Jay » Sun Dec 27, 2015 12:01 am
Late to the party as usual and just came upon this thread. Wow. Excellent. Great stuff! I say sticky and wiki.
Jay
kg4miq wrote:Sorry to resurrect the old thread, but I'm in the process of doing this today and thought I'd share.
For the 4ZE1 distributor (and possibly for the 4ZD1 as well, I'll have to check), the internal oil seal in the distributor is a NOK 3286, dimensions are: 12.45mm x 22mm x 6mm. This is the same seal Honda Accords used on the F22B1, F23A1, F23A4, and F23A7 engines, FYI.
1989 RS White, 2.6 4ZE1, 5 speed, AMC head, auto trans radiator.
My RS: http://tinyurl.com/3e5w5b8
Jay
Has thanked: 17 times
Have thanks: 16 times
Postby kg4miq » Sun Dec 27, 2015 9:44 am
Thanks for all the kind words of support! I just noticed I had not followed up on whether or not the inner seal on the 4ZE1 was the same as the 4ZD1, and it is, so that makes it much easier when rebuilding these.
Hope this helps!
kg4miq
Postby T89 » Mon Dec 28, 2015 10:50 am
Excellent write up. I just rebuilt my distributor. It's easy with a bench vise but I did have a folly, I hadn't seated the seal all the way so when I put it back together the shaft wouldn't spin. The disc in there was bound up in the sensor as it wasn't aligned. I took it apart and pressed the seal the rest of the way down (I was afraid to damage it and thought it was seated all the way the first time). I had to use another disc from a spare distributor I had because I bent the other one when the seal wasn't seated and I had put it back together that way. It is so thin you don't even feel it getting mashed. If you put it together and the shaft doesn't turn don't force it; just take it apart and drive the seal all the way down.
1989 Isuzu Trooper 2.6 5-Speed
T89
Have thanks: 27 times
