Largest tire that can mount on 2001 rodeo rear door
What fits and What performs
Postby chuff67 » Sun Mar 15, 2020 12:24 pm
Hi planet Isuzu peeps,
I am finding a lot of info on largest tires or wheels that can be run w/ various lifts, etc., but... Can anyone tell me what the largest tire is that can be mounted on the stock spare mount on the rear door of a 2001 rodeo. I installed a 2.5" lift on mine and would like to run 31's, but not sure if this will fit? Any help/advice would be greatly appreciated...
Thanks, Chris
chuff67
Re: Largest tire that can mount on 2001 rodeo rear door
Postby kmcmilla » Mon Mar 16, 2020 11:26 am
I put a wheel spacer on the factory mount and stuck a 245-70-16 tire on it, fits perfect. I did have to grind down the little nub that holds the tire from falling when unbolted.
'01 Rodeo Sport - 4x4 3.2 V6
kmcmilla
Has thanked: 12 times
Have thanks: 7 times
Postby chuff67 » Thu Mar 19, 2020 9:59 am
Oh wow. Never thought of that option. Any info you could provide on the spacer you used? Thanks much.
chuff67
Postby kmcmilla » Thu Mar 19, 2020 9:26 pm
Standard 1” spacer
kmcmilla
Postby chuff67 » Fri Mar 20, 2020 8:49 am
Got it. Thanks and much appreciated!
chuff67
