PlanetIsuzoo.com (Isuzu SUV Club)
Welcome to the Planetisuzoo Forums!
It is currently Wed Sep 30, 2020 4:25 pm
Post new topic Reply to topic  [ 7 posts ]
Author Message
PostPosted: Tue Sep 15, 2020 7:10 pm
Offline
Ok so being rather new to 4wd and snow I know very little.
We already have a vehicle that is great in the snow and we use it daily so it has hakka 9 studs. It has very little off road ability and is limited when snow passes 6 or 7 inches.
Looking at some blizzak studless tires so we have something that can road trip up to and over the pass for christmas and such then not destroy tires on the warmer coastal highways. They are gonna grip the snow and ice but will they basically destroy my off road winter ability?
Am I better off with one of the winter oriented AT tires knowing from experience that something like a falken wildpeak w the 3 mountains will NOT behave like a true snow tire?
They will be winter only and off roading in winter will be limited to forest service roads and up to 12 inches of snow. Nothing major.
We live in the kittitas valley so local roads will frequently be icy enough to warrant studs but are generally well plowed. Just packed and gravelled streets. But it can start in early October and last til March.
Thoughts or experiences?
 Profile
PostPosted: Tue Sep 15, 2020 8:00 pm
Offline
I run Cooper Discoverer AT3 on my 2000 trooper. I take it up in the mountains in western Montana elk hunting in the winter I have taken it up some pretty sketchy mountain roads, I do take snow chains , a shovel and recovery gear although have only had to use the recovery gear to pull other people out.
 Profile
PostPosted: Tue Sep 15, 2020 8:36 pm
Offline
What size?
 Profile
PostPosted: Tue Sep 15, 2020 9:28 pm
Offline
right now I have 255/70R16 on the 2000 trooper but when I replace them will likely go to 245/70R16 just to match some other vehicles I have .
 Profile
PostPosted: Wed Sep 16, 2020 3:32 am
Offline
245/70 16 is the stock size and you'll find slightly better prices in that size because it's more common (on LOTS of older GM trucks and others). I'd shop that size and then not worry about it.
Here's what I'd do if I were you:
A) wait until October and then when GM's fall tire rebate is on, get a set of Hankook AT2's installed for about $300 OTD (Yes), with lifetime balancing/rotation/etc. Twice a year GM will give a $200 rebate on tires purchased from them if a) brand is Hankook, Bridgestone, Pirelli, Conti, Goodyear. Less rebate for other brands. Must use the GM buy power card for maximum rebate, but you don't have to pay interest. Just pay the card off when it comes. GM will price match the lowest dealer/installer price within 100 miles, so if you have a Walmart in that distance, you get their prices PLUS the rebate. Amazing deal.
B) Since they do Bridgestone, you could do Blizzaks, too. I am putting either Blizzaks or Hankook I-cept on my (new to me) Volvo XC70 to use a a ski car to go up to Snoqualmie Pass, over to Wenatchee and Mission Ridge a lot this winter (instead of the Trooper/SLX).
c) Last fall, I used the GM deal to get the Hankook Dynapro HT installed (highway tread). it was about $270 after rebate (245/70-16). Rebate was fast and painless, btw. Anyway, a month after I went with the HT, I decided to start skiing again after a big break. I started teaching lessons up at Snoqualmie Summit and was going up there three days a week. I was really hating my decision to go with the HT instead of the AT, BUT - the truck did fine in ALL conditions all winter (until Covid at least!). I was surprised. Given what you said, I'd go AT2, take the great deal, and not look back.
I did some "mild" offroading on the Dynapro HT tires this past summer. Deflated them to 25lbs and they were great on dry forest roads and some trails, like the stuff above Liberty if you know that. I had zero complaints with them. In retrospect, I should have gone AT2 and I'd be happier all-around.
If you want dedicated snows, the Blizzak is good, but know two things: 1) the soft winter compound is the upper 1/2; it gets harder down lower so once you are down to 1/2 tread they are toast for pure winter use. 2) Also, in your heat in the summer, they will wear badly and be really soft and floaty - I have run winter tires year-round before on the East coast (I used to live in NY and VT, and norther VT at that). You could run the winter tires in norther VT in the summer, but if you went south where it was hotter, they got sketchy at speed and with heavier vehicles.
Oops, just re-read and saw this:
"They will be winter only "
In that case I would get the Hankook I-cept. It's a better non-studded tire than the Hankook I-pike (a lot of gripes with them when not studded), and will give longer winter service than the multi-compound Blizzak.
I focus on Hankook and Bridgestone here as those can give you very good snow tires at great prices, and thus maximize the GM rebate and price-match. There are lots of good other snows out there, but these can be had at amazing prices. Usually the rebate period is for tires purchased 10/1-11/30 (and again march/april they do it), so I'd wait until at least the first of October to see that deal pop up. here's a link to the terms for the last deal:
https://media-dmg.assets-cdk.com/teams/ ... 8ba825.pdf
It ran sept. to Nov last year, I think normally it's Oct to Nov. Also, sometimes Ford dealers do the exact same deal.
_________________
 Profile
PostPosted: Wed Sep 16, 2020 11:28 am
Offline
Ok I followed uo on that link and I'm gonna look into that card... I have a discount tire card but the deal they have going is half that even using the card.
I ran i pikes and even with studs they PALE to the Nokian hakka 9. Those grip so well that snowy roads become a playground. They not only grip like crazy but they handle like the best sport tires Ive ever used. Breaks away gradually and ultra predictably. You can alter your line through the turn with just a quick throttle adjustment and in 3 years of trying Ive never spun out.
But i am not asking for that kind of performance from the squarebody trooper platform lol. My real concern is if a studless pure snow tire will work on forest service roads that arent plowed and have 6-12 inches on top of some hard pack, ice or gravel.
Also having never run studless I am unsure what to expect from them in general. The hakkas love deep snow on fs roads but the civic only has 6 inches of clearance.
Thanks for the great post!
 Profile
PostPosted: Wed Sep 16, 2020 12:04 pm
Offline
nateintacoma wrote:
= My real concern is if a studless pure snow tire will work on forest service roads that arent plowed and have 6-12 inches on top of some hard pack, ice or gravel.
Oh sure, no problem.
I lived in northern VT for years and I worked as a ski patroller. I had to be at the mountain before the roads were plowed. I never bothered with studs - just good tires (Blizzak and Yokohama snows), and Quattro. Never a problem - at all. I even drove it on snowmobile trails sometimes for fun.
I thought last winter, in a lot of snow, I'd be disappointed with the Trooper TOD system vs. the pure mechanical TorSen I was used to. I was wrong - the TOD system is quite good. It and four snows w/o studs will suit your needs and not have the downside of the noise, performance on wet/dry.
_________________
 Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Jump to:
Powered by phpBB® Forum Software © phpBB Group
VigLink badge
