'90 Amigo "Sanchez" build thread
Re: '90 Amigo "Sanchez" build thread
Postby troopergal00 » Thu Dec 10, 2015 10:51 am
I just realized that I only put the pics of the new seats and console on facebook but not on here. These were put a couple of months ago but better late than never. Hopefully with Lou being off for a few weeks over the holidays he can get Sanchez closer to being drive-able again.
Kate, 2000 Trooper "Bane", 3.5 liter V6 Automatic, 1990 Amigo "Sanchez", 2.6 liter 5 spd
Bane's Build Thread
Sanchez's Build Thread
troopergal00
Postby mudoilngears » Thu Dec 10, 2015 1:30 pm
Nice! What vehicle is that console from? I need one for my Migo! Especially like the CB in the E-brake slot!
1998 Rodeo LS 4x4 4JB1-TC Diesel Swap, Moog CC247 coils, more mods to come!
Build in progress...
For this post the author mudoilngears was thanked by:
troopergal00
mudoilngears
Has thanked: 19 times
Have thanks: 178 times
Postby troopergal00 » Wed Dec 16, 2015 1:26 pm
It came out of a newer rodeo, not 100% sure on the year (Lou could probably pipe up with that tidbit of info). There are also consoles in rodeos with a thicker padding on the top but all the ones we kept finding were ripped up. Fairly easy to mount into the Amigos and gives some much needed storage space!
Bane's Build Thread
troopergal00
Postby troopergal00 » Mon Apr 18, 2016 7:56 am
Just some pictures of the most obvious progress we made this weekend on Sanchez. Went and got some 285x75x16 BFG KO2s put on the flakes. Also got the brakes sorted out and got the timing and the three leaky oil seals replaced on the front of the motor. Still have a few things to finish up but hopefully can have it ready to at least show up at Uwharrie for the meet on the 30th in two weeks.
Bane's Build Thread
troopergal00
Postby -88- » Mon Apr 18, 2016 12:44 pm
I wanna lay you down in the bed of an Amigo......
wait I don't think that's how that song goes :/
I've said it b4, I'll say it again....looking awesome Kate.....& progress is always brilliant. Doubly so if your mechanic requires a cattle prod for motivation.
For this post the author -88- was thanked by:
troopergal00
Has thanked: 15 times
Have thanks: 103 times
Postby troopergal00 » Tue Apr 19, 2016 11:14 am
Here's a couple more pics from our work this past weekend. Had to use a torch to get the front wheels off, they were wedged onto the hubs. And look at that paracord engineering holding the e-brake cables together!! There's also a soup can in the exhaust, but no pic of that, sorry! :lol:
Bane's Build Thread
troopergal00
Postby shaggydoink » Wed Apr 20, 2016 9:11 am
The Amigo is looking great, keep up the fantastic work!! :thumbup:
Shaggy
Has thanked: 807 times
Have thanks: 413 times
Postby superman27344 » Thu Apr 28, 2016 10:13 am
Here is the video you took the other night of me driving it after I got it running. Thought you might want it on your thread. :)
Watch on youtube.com
Lou
2000 Trooper aka "Brawn", 3.5 liter V6, 5spd
1989 Trooper aka "The Armadillo", 2.6 liter, 5spd SOLD
Carolina Isuzu Owners
Brawn Build Thread
The Armadillo Build Thread
"It has been my experience that folks who have no vices have very few virtues."
-Abraham Lincoln
Has thanked: 430 times
Have thanks: 78 times
Postby troopergal00 » Fri Apr 29, 2016 10:58 am
So, as you can see in the above video....Sanchez is ALIVE!! Got her all put back together and she wouldn't turn over. We replaced the fuel pump, fuel filter and plug wires before finding the real issue. Here's is Lou's explanation of the problem......
I didnt pull the distributor but I did change the plugs, wires, cap, and button. Well since I was going back all new, I just pulled everything off at once and didn't pay attention to the fact they had the plug wires on wrong. Apparently the last person who wrenched on it had pulled the distributor, put it in wrong, and in order to make it run, just switched the plug wires. When I put everything back together, I put the plug wires to the correct cylinders according to the firing order like I always do, not knowing the distributor was in wrong. Last night when I got home after having a day to clear my head, I checked the engine timing to make sure it wasn't off a tooth like people had suggested and of course it was good. Luckily though, I had the upper timing cover still off when I decided to make sure something wasn't funky inside the distributor. As soon as I pulled the cap I saw the rotor button pointed to the wrong contact. I went and checked the old cap and wires and figured out what they had done. Instead of continuing with their lunacy, I pulled the distributor and put it in correctly. Fired up on the first try. Lesson learned though, just because I didn't pull something, doesn't mean someone else didn't.
Bane's Build Thread
troopergal00
Postby troopergal00 » Fri Apr 29, 2016 1:25 pm
New exhaust, sounds sooo much better :D
Bane's Build Thread
troopergal00
Postby cyal » Sat Apr 30, 2016 7:06 am
Hello. What´s the brand of the beldliner? in the page 1 first photo what´s the size of the tires and wheels? 225/75 r 15? thanks
cyal
Drives in Mud
Postby -88- » Sat Apr 30, 2016 2:02 pm
285/75r16
As for the bed liner I think it's just a rattle can variety, but maybe not. Kate & Lou are out at URE, when they get back they can clear it up better.
Postby troopergal00 » Thu May 12, 2016 3:47 pm
cyal wrote:Hello. What´s the brand of the beldliner? in the page 1 first photo what´s the size of the tires and wheels? 225/75 r 15? thanks
Not sure what brand of bedline was used before but we used the aerosol version of Dupli-Color Bed Armor. I sprayed a few coats on the damaged areas and then did two coats over the whole thing to make a nice even coat. The tires that were on the crappy nissan wheels in the first photos were 235/75 r15s but I do not recall the brand of them. The new tires that are on the 16" flakes are 285/75 r16s and are BFG AT KO2s.
Bane's Build Thread
troopergal00
Postby troopergal00 » Thu May 12, 2016 3:50 pm
Here are some pics I took after finally washing Sanchez. Cleans up pretty nice.
Bane's Build Thread
troopergal00
Postby troopergal00 » Thu Jun 09, 2016 9:13 am
Just wanted to add a couple of poser pics of Sanchez at the top of Daniel from a couple of weeks ago. This was my first time taking it off road and I wanted to kill my husband for making me go up the backside of Daniel for my first trail of the day, but it was really fun and it did really well. I was supposed to wheel it the next day as well, but a burst power steering line had Sanchez sidelined that day. The line has since been replaced so hopefully Sanchez will be on a trail again in the near future. :)
Bane's Build Thread
troopergal00
Postby shaggydoink » Fri Jun 10, 2016 6:47 am
You should be proud, that's not the easiest of trails at times!! :thumbup:
Shaggy
For this post the author shaggydoink was thanked by:
troopergal00
Postby totten » Sun Jul 03, 2016 8:26 pm
I have always like the early Amigos. Thanks for pics,Tony
2004 rodeo 4x4,3.2,aw3040ls automatic,Stock springs with Independent4x 2"coil spacers, Zone 2" Body Lift, 285/75/16 Mastercraft Courser HXT Tires. Cobra 29LTD CB,Transmission cooler,Functional hood scoop,kyb shocks
totten
Have thanks: 107 times
Postby troopergal00 » Sun Jul 03, 2016 9:11 pm
Thanks all! Just got a new top put on a couple of weeks ago and off-road bumper and winch coming soon! :D
Bane's Build Thread
troopergal00
Postby mmceorange » Tue Nov 15, 2016 12:54 am
-88- wrote:Yea it's not too hard to swap, but you've got to have all the hardware. The track from the quarter window setup doesn't properly support the full size glass.....Or if body color matches, or one doesn't care swap the whole door.
ur right it's also a matter of personal taste/preferance......I'll take the big window door all day every day, I like the mirror much better. It's bigger, & the glass moves in the housing not all 1 piece, my all 1 piece spacer mirrors are heavily affected by the wind.....most importantly tho with the big window.....there's no little triangle window to worry about sealing.
Old post, I know, but.. Do you know if it is just as easy to convert from big window to vent glass style? I like the look much better, and have both styles, but the older doors are rotting at the bottom.. so door swap is probably not a good idea. I was planning on pulling the doors apart for closer inspection, but if somebody already knows...
mmceorange
Postby troopergal00 » Wed Dec 14, 2016 5:20 pm
Been awhile since I have updated here. Back in September Sanchez decided to blow the head gasket. It was down for a couple of weeks until my husband had time to do the job but we got it done and it runs better than ever. Last weekend we went to URE with it and Shaggy was kind enough to be my co-pilot and give me some pointers on how to get Sanchez over the obstacles out there with ease. My husband took the video of me coming up Dutch John for the first time in it.
Bane's Build Thread
troopergal00
Postby shaggydoink » Wed Dec 14, 2016 7:31 pm
troopergal00 wrote:My husband took the video of me coming up Dutch John for the first time in it.
You were cool as a cucumber coming up that scary-ass hill, very impressive! :thumbup:
Shaggy
troopergal00
Postby troopergal00 » Wed Dec 14, 2016 9:01 pm
Great teacher!! :)
Bane's Build Thread
For this post the author troopergal00 was thanked by:
troopergal00
Postby troopergal00 » Tue Feb 07, 2017 3:26 pm
Picked up the Amigo from Joe Darlington the other day and the bumper he made for it looks amazing. Next up will be ordering a winch for it.
Bane's Build Thread
troopergal00
Postby paulevans76 » Tue Feb 07, 2017 4:11 pm
Looks great.
MUA5 w/ 3.07's & fixed yoke
Warn XD9000 w/ synthetic rope, rear swing out tire carrier
1.5" body lift and fuel tank lift
1994 Samurai - 1.3 FI - topless mini wheeler in the works
Has thanked: 222 times
Have thanks: 181 times
Postby shaggydoink » Sun Feb 12, 2017 12:02 pm
It looks amazing!
Users browsing this forum: No registered users and 18 guests
