A boy and his Trooper (very pic heavy)
Re: A boy and his Trooper (very pic heavy)
Postby shaggydoink » Sat Jan 17, 2015 10:30 am
I am a total junkie when it comes to things like these original ads and brochures, and while my wife reminds me that in some instances things can be bought off eBay, I get even more jazzed when things are simply found "in the wild" so to speak. Great score, and thanks for sharing!! :thumbup:
Shaggy
Has thanked: 807 times
Have thanks: 414 times
Postby redcentinela » Tue Sep 01, 2015 2:45 pm
That's passion!
redcentinela
Mi Amigo
Postby hessmess » Sun Sep 06, 2015 10:19 am
A couple of those scanned picts gave me an idea of what my original spacer color is like. It is now a bit faded from all the years in the high desert.
88 Trooper (recycled)
https://forum.planetisuzoo.com/viewtopi ... 15&t=81567
89 Pup LS Space Cab, 4X4, 2.25 cat back exhaust system, LSD, Jerry Cam, otherwise stock, painted Oct 2018.
https://forum.planetisuzoo.com/viewtopic.php?t=55081
hessmess
Have thanks: 173 times
Postby totten » Tue Jan 12, 2016 11:37 pm
You did great job of posting everything done. Thanks for the pictures.
2004 rodeo 4x4,3.2,aw3040ls automatic,Stock springs with Independent4x 2"coil spacers, Zone 2" Body Lift, 285/75/16 Mastercraft Courser HXT Tires. Cobra 29LTD CB,Transmission cooler,Functional hood scoop,kyb shocks
totten
Have thanks: 107 times
Postby onemanarmy » Thu Jan 14, 2016 11:04 am
did you ever get the carb swap done?
and why go the carb route? Seems to me that getting a carb setup to pass emissions would be more difficult.
1991 2.8 5 speed black Trooper SE
http://www.platetees.com
onemanarmy
Rodeo King
Postby electricpuppyboy » Fri Jan 15, 2016 2:33 pm
Thanks everyone!
I have not yet completed the carb swap. I've gotten as far as dropping the tank, and removing the FI system/intake. I've had many other things that take priority over Trooper "fun" lately. I'm sure many of us can commiserate.
I decided on the carb swap because of the successes that other folks on here were having with it. As my truck is now 25+ years old, I no longer have to worry about emissions testing in my state.
-Bob
1988 Trooper LS 4ZE1 mua5 - "Build" Story
1990 Trooper S 4ZE1 mua5 - gone
1989 Trooper RS 4ZE1 Auto - gone
1989 Trooper LS 4ZE1 Auto
For this post the author electricpuppyboy was thanked by:
RickP
electricpuppyboy
Has thanked: 32 times
Have thanks: 44 times
Postby PPCLI-JIM » Sun Jan 17, 2016 1:53 am
I've also have considered it. as it would get me around whatever it is thats making my Trooper act all italian :D
97 Rodeo 3.2 AKA THE PAVEMENT PRINCESS pretty much stock DEAD PARTS DONOR
88 TROOPER II 2.6 Auto Weber 32/36 Carb 9k Winch
95 Rodeo 3.2 Manual AKA Frankenstien this will be off roadered
91 Rodeo 3.1 Auto The GREY GHOST new highway runner
9 ft 1963 Harbercraft
12 ft fiberglass boat
14ft 1962 Powercat 14T boat
Fishing Rods lots of those !
PPCLI-JIM
Trail Scout
Has thanked: 50 times
Have thanks: 18 times
Postby electricpuppyboy » Fri Mar 08, 2019 10:52 am
Just a quick update:
Last summer I re-installed the tank and fuel injection system. I didn't have enough confidence to do the carb swap. When I put everything back together I "deleted" the EGR tube (I left the valve and plugged where the tube was with bolts). Everything else went back together as I had it before but I can't get it to start. I have good fuel pressure up to the rail and I bench tested all the injectors. It will start if I spay ether into the intake though (so I must have spark, right?). I'd really like to get this running again, so if anyone has any ideas, I'm all ears.
-Bob
electricpuppyboy
Postby itsmehb » Fri Mar 08, 2019 11:07 pm
Wow, lots of work and then no start. So where to start. Well, your first assumption is correct. It would not start, period, if you didn't have spark. So the fact that it will start using spray, we can assume the ignition is not the issue. Next would be the fuel system. Is the pump running? Is there any pressure at the fuel rail. That may be the next thing to check. Also, the filter could be stopped up. It's hard to get to as it's under the car forward of the rear axle on the right side. There's some other issues but I think first would be to establish fuel pressure at the rail.
1991 Pick up (long gone)
2000 Amigo, 2.2 5 speed(sold)
itsmehb
Has thanked: 152 times
Have thanks: 321 times
Postby DSUZU » Sat Mar 09, 2019 8:30 am
Since you say you have pressure at the rail, SOMETHING is keeping your injectors from firing. Any chance you unplugged the injector resistor pack on the right fender well? Double check all electrical plugs. Dennis
Has thanked: 284 times
Have thanks: 977 times
Postby itsmehb » Sat Mar 09, 2019 9:51 am
DSUZU wrote:Since you say you have pressure at the rail, SOMETHING is keeping your injectors from firing. Any chance you unplugged the injector resistor pack on the right fender well? Double check all electrical plugs. Dennis
My bad. I read the post where you said you had pressure at the rail, then posted that you should check that.
itsmehb
Postby electricpuppyboy » Sat Mar 09, 2019 10:56 am
Thanks guys! Yes, fuel pressure at the rail. I did put a new fuel filter in when I re-installed the tank.
Dennis, you jogged my memory a little. After I put everything back together and had this no start issue, I replaced the entire fuel injector wiring harness with one from a parts rig thinking there may be something wrong with the original (the wires were pretty stiff / brittle). I didn't, however, trace anything back any further than that. I'm unfamiliar with the injector resistor pack. What exactly am I looking for / what does it look like?
-Bob
electricpuppyboy
Postby MarkB.NV » Sat Mar 09, 2019 5:16 pm
MarkB.NV,
Black 1989 RS, 2,6 / 5 speed, 149K mi.
Tan 1986 Trooper, 2.6 / 5 speed, 173K mi.
Sold ... White 1984 Trooper, 1.9 / 4 speed
Sold ... Silver 1990 Trooper, 4 cyl, 5 speed
Sold ... Blue 1989 Trooper, 4 cyl, 5 speed
MarkB.NV
Has thanked: 98 times
Have thanks: 149 times
Postby electricpuppyboy » Sat Mar 09, 2019 10:28 pm
Perfect! Thanks Mark! I'll check it out.
-Bob
electricpuppyboy
Postby electricpuppyboy » Tue Jan 14, 2020 2:45 pm
Ok. So this is where I am now.
1) I checked the plug that Mark suggested. Everything was connected securely. I unplugged and plugged it back in a few times (just for good measure). It still just cranks without starting.
2) I bought an in line spark tester (never had one before). When plugging that in and cranking I don't get any light.
3) Knowing that I don't have spark, I checked the following:
- checked to make sure the plug going to the dizzy is securely plugged in (the one with the round connector). I've had issues with this in the past, but it seemed fine.
- checked that there was good ground to the ignition control module (there was)
- Swapped the ignition control module with a spare I had, still no spark.
- In tracing the wires for the dizzy (the ones to the round plug) I noticed that there were a little bundle of three wires that went to an eyelet that wasn't fastened anywhere. I assumed that this could only be ground (right?), so I grounded it. Still no spark.
- I also checked the ignition coil fuse and swapped the engine relay with the AC compressor relay. Still no spark. (I'm not even sure what the engine relay does, but I was grasping at straws).
Some additional details:
Some of the stock components have been moved, removed, or bypassed. It's been at least 2+ years since I've worked on this, so I'm having a hard time remembering everything I did (or why).
Moved:
- The ICM: to the top of the valve cover
- This thing from under the plenum to the front of the common chamber (it's upside down now, does that matter?):
- The temp sensor to here (I think this is where the thermal valve was, so that has been removed)
** Also note that I plugged the port on the intake tube in that pic. I think that also went to the thermal valve.
Bypassed:
- This thing (VSV?):
- These vac lines:
Removed:
- The EGR tube. Both ends have been plugged, but the valve is still in place:
Additionally, the smog pump and associated components were removed many years ago (but the truck had been running since).
If anyone has any ideas, I'm all ears. If anyone sees anything in the pics that I need to change, move, remove, add, etc. let me know.
As always, thank you all for all your help!!
-Bob
electricpuppyboy
Postby shaggydoink » Sun Jan 19, 2020 9:45 am
Is the valve cover ground OK? I had a "no spark" situation at one point in the past and this was the culprit, the original wire ribbon had broken off from the connector in its age.
Postby gruff54 » Mon Jan 20, 2020 7:30 am
Double check all grounds. I had a no spark issue after a head replacement a few years ago. All grounds were in place, as far as I could tell. I finally made up and installed one or two additional/duplicate grounds and I had spark. Never did find out which one wasn't good, just left the additional grounds in place.
Mike
'88 Trooper 2.6L 5 spd
'89 Trooper 2.6L 5 spd
gruff54
Has thanked: 44 times
Have thanks: 85 times
Postby electricpuppyboy » Mon Jan 20, 2020 10:05 am
Thanks Shaggy & Mike! I'll check all the grounds and report back.
-Bob
electricpuppyboy
Postby electricpuppyboy » Tue Apr 28, 2020 9:16 pm
Bingo. It was the grounds!
https://youtu.be/D9w50rvlFfE
Watch on youtube.com
-Bob
electricpuppyboy
Postby electricpuppyboy » Wed Apr 29, 2020 8:29 am
So, if you've clicked the link to the youtube video, you have seen that the idle is quite high (1800~1900 RPM). I assume this is due to the bypassed components. All I should need to do is use the adjustment screw to bring that back down, correct?
pic borrowed from Shaggy:
-Bob
electricpuppyboy
Postby electricpuppyboy » Sun May 03, 2020 8:42 pm
Ok, I adjusted the idle down. It seems happy to be at around 1300, but lower than that it wants to stumble. One thing it's going is surging a little (between 1250-1350 or so). It's got some old gas in it, so maybe I just need to burn through that (put some seafoam in the tank?).
I took the weekend and get her cleaned, and all the missing pieces bolted back on (gas thank skid plate, mirrors, front bumper, back bumper). I also swapped the hood for a better (less dented) one, installed my hood scoop, and the Lund visor. The DMV out here it still closed until next week, so I won't be able to get it back on the road until then.
Here's how she sits now:
-Bob
electricpuppyboy
Postby electricpuppyboy » Wed May 06, 2020 1:14 pm
So this is what it does at idle:
https://www.youtube.com/watch?v=8fTrup1 ... e=youtu.be
Any thoughts on cause?
-Bob
electricpuppyboy
Postby electricpuppyboy » Fri May 22, 2020 11:26 am
I've run some fresh gas through it and the "surging" has gone (though my idle is still a little too high). I believe my dizzy timing is a bit too far advanced (as I get some pinging under hard acceleration).
I had the fuel pump go on me:
Instead of dropping the tank (again), I opted for the access panel method:
Worked like a charm too! Had everything wrapped up and the truck running again in a couple of hours.
-Bob
electricpuppyboy
Postby electricpuppyboy » Fri May 22, 2020 11:27 am
I also picked up another toy:
-Bob
electricpuppyboy
Postby 93trooperpooper » Fri May 22, 2020 10:23 pm
electricpuppyboy wrote:I also picked up another toy:
i like it. 8)
will drive these until they quit and move onto something else.
parts from JERRY LEMOND.
93trooperpooper
Have thanks: 27 times
Users browsing this forum: No registered users and 12 guests
