Black&White Trooper 2001
Postby vovkus » Sat Jan 08, 2011 2:40 pm
Just start work on it. Will post pictures during process.
2001 Trooper LS with AISIN 30-40LE transmission and 4" lift
vovkus
Trail Scout
Has thanked: 2 times
Have thanks: 6 times
Postby Mediamonkey11 » Sat Jan 08, 2011 4:49 pm
Me = jealous!
-Tony-
viewtopic.php?t=46954
1996 Trooper LS 4X4 3.2L SOHC - Airtec Snorkel - 6000K BiXenon HIDs - 16x7.5" Snowflakes - ARB Front Winch Bumper - Vortex 12000lb Winch - Superwinch Manual Hubs - 3" lift OME 919's + Coil Spacer -OME Nitrochargers - HD Lower Links - Low Profile Droop Snubbers - Poly SwayBar Bushings - Ball Joint Flip + 1/4" Spacers, Pioneer Head Unit, Polk 6X9's in the rear doors, Polk 6.5" Front Components, Coustic 4ch 1200W Amp, Diamond Audio D912D4 12" Sub, Sub Zero 12" Vented Box.
Mediamonkey11
Has thanked: 7 times
Have thanks: 20 times
Postby vovkus » Sat Jan 08, 2011 7:43 pm
Rear before:
After:
vovkus
Trail Scout
Postby jwood1016 » Sat Jan 08, 2011 7:47 pm
YOu are going to be very pleased with those calmini springs.
John
2002 Trooper
3 inch lift and 33's
jwood1016
Have thanks: 18 times
Postby vovkus » Sat Jan 08, 2011 8:23 pm
Before that, I use OME919 with 2" spacer. I was able to put in Calmini with same spacer.
My measurements before update (front stock torsion bars/rear OME919+2")
Front Left 37.5" Front Right 38.25" Rear Left 36.25" Rear Right 37".
Have no data after update yet. Still in the process.
vovkus
Trail Scout
Postby vovkus » Sat Jan 08, 2011 9:39 pm
Based on Calmini manual the torsion bars supposed to be marked as L and R
I got both R!!!!! Anybody have this problem?
vovkus
Trail Scout
Postby vovkus » Sat Jan 08, 2011 11:25 pm
Front before:
After:
I decided to install left side torsion bar with 180 degrees swap.
vovkus
Trail Scout
Postby vovkus » Sun Jan 09, 2011 12:39 am
Measurements after upgrade:
LF 38 3/16 RF 38 1/8
LR 38 3/4 RR 38 1/2
Will re-adjust bars tomorrow.
Now it is time for the test drive :)
I like it on FW. Way better. Almost no body roll.
vovkus
Trail Scout
Postby Metal88 » Sun Jan 09, 2011 12:45 pm
umm i dont know about the torsion bar man if that thing snaps on high speeds you might loose control
Sal
-If you don't put any effort in anything you do in life, you mine as well be a vegetable- Burt Munro
Metal88
Have thanks: 13 times
Postby vovkus » Mon Jan 10, 2011 2:41 pm
I spoke with Calmini tech support. They confirmed, that I did right installation.
vovkus
Trail Scout
Postby Metal88 » Tue Jan 11, 2011 12:54 am
vovkus wrote:I spoke with Calmini tech support. They confirmed, that I did right installation.
alright then how about some flex shots :wink:
Sal
Metal88
Postby vovkus » Tue Jan 11, 2011 12:59 am
Not ready yet for pictures.
vovkus
Trail Scout
Postby vovkus » Sun Feb 06, 2011 11:16 pm
just one :)
vovkus
Trail Scout
Postby Metal88 » Mon Feb 07, 2011 6:07 pm
NICE!!!
Sal
Metal88
Postby beto » Mon Feb 07, 2011 8:14 pm
That´s great! I´m very happy for you keeping the trooper :wink:
Keep the pics coming :P
2002 Trooper, 3.1 Turbo Diesel Intercooled
Front Aussie Locker // OME 919´s // Daystar 1.5" spring spacers // Pro Comp ES9000´s // ARB Bumper // 12,000lb Winch w. Synthetic Rope // BFG KM2 255.85.16 on Snowflakes
Lifetime Led Headlights // RigidIndustries Dually D2´s // Aisin Hubs // 4 LED Roof Spot Lights // OEM Yakima Roof Racks // Airtec Snorkel // K&N Filter
video // video // 12/2010 ROTM
beto
Have thanks: 38 times
Postby vovkus » Mon Feb 07, 2011 9:59 pm
After careful measurements, I discovered about 0.5" rear axle misalignment.
Have to install adjustable rear links to fix this problem. Got materials for links today and will try to complete this project over this week.
vovkus
Trail Scout
Postby vovkus » Thu Feb 10, 2011 12:35 am
The new links are ready. It took about 1.5 hrs to build them.
Will install them tomorrow.
vovkus
Trail Scout
Postby vovkus » Thu Feb 10, 2011 11:25 pm
Installed:
vovkus
Trail Scout
Postby jwood1016 » Thu Feb 10, 2011 11:31 pm
Hey what was the purpose of the new links??
John
2002 Trooper
jwood1016
Postby vovkus » Fri Feb 11, 2011 1:43 am
The frame is a little bit twisted after accident. Now I was able to adjust rear axle position.
vovkus
Trail Scout
Postby tonnydoodles » Fri Feb 11, 2011 10:00 am
those front sway bar links came with the calmini bars or you had them custom made?
"if you make something idiot proof, someone, somewhere is raising a better idiot" 99 trooper,98 land cruiser,99 trooper
tonnydoodles
Has thanked: 19 times
Have thanks: 26 times
Postby vovkus » Fri Feb 11, 2011 6:00 pm
The front links are Moog Sway Bar links.
Part numbers: K90703, K90702 (left and right)
Available on amazon.com for 24.90 each.
vovkus
Trail Scout
Postby Triathlete » Sat Feb 12, 2011 6:15 pm
Great job Vovkus. Those links turned out nice. Where did you order the materials for them from? What did it cost you?
Will we be seeing you in Moab this year? :D
B.Oliver
15xIronman
'99 Ebony VX lifted, and used!
Accelerate3Coaching
Team TriSports.com
15% discount code BOLIVER
Triathlete
Postby vovkus » Sun Feb 13, 2011 4:59 am
Rod ends and tube inserts I got from mckenzies. Tubing from local metal supply shop. Total cost of this project $340.
I wish everything will be OK and I will be able to do trip to Moab this year.
vovkus
Trail Scout
Postby Triathlete » Mon Feb 14, 2011 1:14 am
Thanks.
Hope you make it...been a while since seeing you out there.
B.Oliver
15xIronman
Accelerate3Coaching
Team TriSports.com
Triathlete
Users browsing this forum: No registered users and 14 guests
