89 Pickup 4WD Beater Project
Postby szac » Fri Jan 01, 2021 12:22 pm
This forum has been an incredible resource. So with this beater now in my garage for past month and a half I figure it's time to start posting progress updates. I bought the truck as a project and have a steep learning curve ahead. I've already started a "4ZE1 tune up priorities" help request thread so I'll just pick up where I've off there.
What is it?
  • 1989 Pickup 4WD 5sp
  • ----Build plate----
  • M.D. TFS7SC AH/IJ
  • ENGINE RLJ -4ZE1 ENG
  • GRADE RBA -INTERIOR BASIC [KB]
  • TIRE 9JG -FRT&RR 31X10.5R15 15X7JJ
  • BODY TYPE ER8 -ISUZU BRAND PACKAGE
  • B.COLOR 834 -BODY COLOR RED MAHOGANY
  • B.TRIM 150 -INTERIOR COLOR GRAY
  • ---- Options -----
  • C41 -HEATER & DEFROSTER
  • ED2 -MANUAL LOCKING HUB
  • S1P -TAIL GATE CENTER PULL TYPE PLAIN
  • S4K -DOOR MIRROR DRIVER & PASSENGER PLAIN
  • S7R -RR BODY DOUBLE WALL CARGO 0.5 TON
  • S9W -BENCH SEAT W/HEAD REST VINYL
  • YM4 -LAMINATED TINTED GLASS
Goal
  • Reliable and capable trail rig for bouncing around AZ backcountry
  • Interior spruced up to point where wife will enter cab
I started out by trying to identify the source of the known fuel leak that the PO said, "happens after the truck sits a couple of days." It didn't leak when I test drove but dumped quite the puddle after it sat in my garage for 2.5 weeks. With help here the plan was to replace all fuel hoses and injector seals. More digging around and Shaggy's thread pointed me to Jim's Injector repair service. I'm glad I did! Jim let me know last night that one injector was bad. I'm replacing it and another reman injector (I believe/hope the source of the leak) with OEM remans from Car-ID.
I got the injectors on their way to Jim on 12/16. Jim will be sending them back to me today or tomorrow. I'm waiting to dig into anything else in the engine until I can start the truck again without a fuel leak. So the past couple weeks I've been focusing on the interior, collecting parts, learning about wiring, gauges, etc. Here's where I'm today on 1/1/21.
2000 Trooper 3.5 4WD 5sp
1989 Pickup 2.6 4WD 5sp
szac
Drives in Mud
Has thanked: 12 times
Re: 89 Pickup 4WD Beater Project
Postby szac » Fri Jan 01, 2021 12:27 pm
More before and after pics:
szac
Drives in Mud
Postby szac » Fri Jan 01, 2021 12:34 pm
szac
Drives in Mud
Postby szac » Fri Jan 01, 2021 12:50 pm
Here's a G80 4.56 that I pulled from a '94 Trooper. Cleaned it up a bit and added it to the pile. First time I ever pulled a third member out of any vehicle and was happy to practice at the junkyard. I thought I was clever to use the driveshaft to try to soften the landing :D sort of worked but still landed on a dirty, fluid soaked floor mat.
As I write this I'm about to head back out and degrease the engine and repair the many many exposed wires including the fat positive battery lead at the starter that was directly below the fuel leak! Yikes!
That red wire is the starter solenoid control and bypasses the loom. It is connected to speaker wire which runs along the firewall, in to the cab and is spliced into the starter at the key. According to the book the only thing this seems to accomplish is bypassing the clutch neutral safety switch. Going to keep it as-is until I get the engine running again then circle back.
szac
Drives in Mud
Postby Tentin » Fri Jan 01, 2021 5:40 pm
The before and after on that seat is impressive. You just used purple power and a brush?
1995 Isuzu Pickup 4WD aka Suzie Q. 3" lift, 32" A/T's
1998 Isuzu Amigo 4WD aka Smeagol The Amigo. 2" Lift, 31" A/T's
Tentin
Have thanks: 13 times
Postby szac » Fri Jan 01, 2021 6:56 pm
Tentin wrote:The before and after on that seat is impressive. You just used purple power and a brush?
Thanks man. Yep, exactly. Also had a water bottle to spray it all down and then hit with the shop vac. I did this maybe 3 times. I still need to steam clean it. Definitely some visible spots there in different lighting.
szac
Drives in Mud
Postby szac » Sat Jan 02, 2021 1:19 pm
Jim sent the results of the testing. One fail on initial testing but then two more ended up leaking. So I have four OEM remans coming from Car-ID. Three (four?) weeks ago my original plan was replace injector seals. So glad I sent them in and hopefully dodged more fuel leaks down the road. Thanks again for the advice, all!
Injectors should be here by Wednesday. Also have a replacement cluster arriving from Romania Tuesday. While endlessly scrolling eBay clusters I noticed it was mislabelled for a late model Rodeo and rolled the dice. I contacted them to ensure that the one in the listing is the one they ship. I confirmed my truck has the proper wiring in place with this post from Lowzone. However in the bay there's a dangling connector of what the book seems to describe as the the tach plug. Also have oil pressure sending unit on the way.
szac
Drives in Mud
Postby szac » Sun Jan 03, 2021 2:35 pm
Question: I'm planning to use this "jumper the fuel pump relay" trick to test for fuel leaks prior to turning the engine over. Any known faults with this or is there a better way to pressurize the fuel system? Thanks!
szac
Drives in Mud
Postby Tentin » Sun Jan 03, 2021 9:11 pm
Don't see why not. Just bridge the connection and you'll hear the fuel pump running
For this post the author Tentin was thanked by:
szac
Tentin
Postby DSUZU » Mon Jan 04, 2021 9:00 pm
While that cluster looks like it MIGHT be right (and I HOPE it is), a Rodeo cluster should not be correct. Rodeos (1991-1994) did not come with a tachometer on the 4 cylinder models (to my knowledge). A v-6 cluster tach will not read correctly. Dennis
Has thanked: 283 times
Have thanks: 955 times
Postby szac » Tue Jan 05, 2021 12:35 pm
DSUZU wrote:While that cluster looks like it MIGHT be right (and I HOPE it is), a Rodeo cluster should not be correct. Rodeos (1991-1994) did not come with a tachometer on the 4 cylinder models (to my knowledge). A v-6 cluster tach will not read correctly. Dennis
Yep, this cluster seems to have come off of a 3.2. I rolled the dice on it after I found this post which describes an adjustment pot inside the casing. I received and cleaned up the cluster yesterday and will be removing casing to locate the potentiometer in question and drill an access hole tonight. Actually calibrating will require tools that I don't have.
The truck currently has a mechanical oil pressure gauge installed where the oil pressure switch installed. I'll keep that in and see how it squares with the oil pressure sender. All wiring on both ends of the loom appears to be present.
The "new" cluster was dirtier than the one I pulled off the pickup. An amazing feat considering the pickup's condition :D
Unrelated to the cluster but it was nice to roll the pickup out of the garage on Sunday for the first time since I parked it there while the boy and I deep cleaned the Trooper.
szac
Drives in Mud
Postby DSUZU » Tue Jan 05, 2021 9:01 pm
Okay, we now need to go down a rabbit trail on this thread. What kind of bike is that in the back? Looks like maybe a regular cycle with a "mower type" engine fitted to it? Gotta know. Dennis
Postby szac » Tue Jan 05, 2021 10:51 pm
DSUZU wrote:Okay, we now need to go down a rabbit trail on this thread. What kind of bike is that in the back? Looks like maybe a regular cycle with a "mower type" engine fitted to it? Gotta know. Dennis
Happy to! It's a '73 Fox Thunderbolt. Back then they called it a "minicycle" - cross between a minibike and dirtbike. We upgraded it with Harbor Freight Predator engine (the Honda clone) and knockoff swingarm from Honda monkey bike. Also has a knockoff comet torque converter. The pickup is currently taking it's parking spot (and a bunch of other crap) in the garage so the bed is getting filled up.
It rips pretty damn good. The shocks are shot so it's hilariously bouncy and weird. Still fun as hell tho.
Here's a better pic for scale. My son is around 6 foot:
Shoved in to the Trooper
szac
Drives in Mud
Postby szac » Sun Jan 10, 2021 1:56 pm
Finally made some progress yesterday! Replaced fuel filter, replaced fuel rail fuel hoses, and installed injectors. The fuel relay jumper trick worked out great and let me catch and fix a leak before turning it over. I have a question but first a theory:
Here's what happened when I arrived at home from picking it up.
  1. Drove home 65mph for 120 miles
  2. I backed it to my driveway, and turned it off
  3. then the truck dumped a bunch of fuel from passenger side engine bay
  4. fired it back and it was squealing horribly (this was new since I turned it off)
Based on the results of the injector repair guy tests I know that one of the inectors was not spraying and was leaking. So maybe the fuel pressure blew the seal when the truck was off (causing fuel dump) and when I fired it up back it was only on 3 cylinders causing the engine to vibrate badly and making the harmonic balancer squeal. Note: I don't know what I'm doing.
Here is my question (finally): Now that it's definitely running all four cylinders again, is it possible for the harmonic balancer to "re-balance" itself? Could running on 3 cylinders permanently kill the balancer?
szac
Drives in Mud
Postby szac » Mon Jan 11, 2021 1:28 pm
Update: the squealing sound is gone. Maybe the harmonic balancer did work itself out?
On to the exhaust. Now that the truck is running again I'm heading to emissions testing. There's a really noisy rattle under the truck (presumably cat) and there's a 2nd, newer looking cat installed after the rattling cat. Any ideas why someone would do this? maybe to save costs on pipe? Here's a super weird stitched together pic of it.
My plan is to roll the dice and see if it'll pass as-is. Then I'll make an attempt to replace it all later myself with 2.5 inch pipe. I've never done it before but greasemonkey makes it look soooo easy (just kidding - looks tough)
szac
Drives in Mud
Postby andy_sykes » Wed Jan 13, 2021 1:53 am
It's cool seeing your progress! Keep posting!
About your squealing, my guess is it was related to the fuel dumped into the engine bay. It might have got thrown on your belts and caused them to squeal.
As for the balancer, unless it was damaged due to the misfire (unlikely unless it was at a point of failure already, or unless you ran it a really long time with a misfire) it's unlikely it will be damaged.
That picture of the exhaust system seems interesting. It could be modified, but the weld doesn't look super terrible.
I was curious so I found a couple answers on some different websites.
https://itstillruns.com/car-need-two-ca ... 62299.html
https://www.quora.com/Why-does-a-car-ha ... converters
So, either Isuzu was trying to push more power and it was cheaper to add a secondary cat, or some previous owner might have had trouble getting it to pass emissions and just decided a junk-yard cat would help.
I'm curious to see what you find, as it seems the trend to add an additional cat is relatively new.
andy_sykes
Postby mudoilngears » Wed Jan 13, 2021 11:13 am
andy_sykes wrote:Iunlikely unless it was at a point of failure already, or unless you ran it a really long time with a misfire) it's unlikely it will be damaged.
Actually the harmonic balancer on these is a well know failure point.
1998 Rodeo LS 4x4 4JB1-TC Diesel Swap, Moog CC247 coils, more mods to come!
Build in progress...
mudoilngears
Has thanked: 19 times
Have thanks: 180 times
Postby Tentin » Wed Jan 13, 2021 6:32 pm
Snapped a picture of my stock exhaust for you, hope it helps. Engine on the left side, picture is taken from drivers side.
szac
Tentin
Postby szac » Wed Jan 13, 2021 8:14 pm
andy_sykes wrote:It's cool seeing your progress! Keep posting!
Thanks and I appreciate the links! Looking at the condition of the two cats it for sure looks like some kind of band-aid junkyard fix to add the 2nd. The rattle is extremely annoying so I'll be looking at it soon.
szac
Drives in Mud
Postby szac » Wed Jan 13, 2021 8:17 pm
mudoilngears wrote:Actually the harmonic balancer on these is a well know failure point.
Ah was not aware. Added to the "shopping list." Thanks!
szac
Drives in Mud
Postby DSUZU » Wed Jan 13, 2021 8:38 pm
Doesn't necessarily mean that YOUR balancer has slipped. You should get #1 cylinder to TDC. You can remove the plug and use a pencil (long one) and rotate crank until it is sticking up as far as possible. Rock crank back and forth a few degrees to verify TDC (or close to it) and see if mark lines up with "0" or if it's a country mile off. Might save you a few bucks. Dennis
Postby andy_sykes » Thu Jan 14, 2021 5:53 am
Good to know!
andy_sykes
Postby szac » Thu Jan 14, 2021 11:41 am
DSUZU wrote:Doesn't necessarily mean that YOUR balancer has slipped. You should get #1 cylinder to TDC. You can remove the plug and use a pencil (long one) and rotate crank until it is sticking up as far as possible. Rock crank back and forth a few degrees to verify TDC (or close to it) and see if mark lines up with "0" or if it's a country mile off. Might save you a few bucks. Dennis
I like saving bucks :D . I've got a new timing belt going in soon, but will check TDC before. The squeal is back but only when starting from cold. It builds for about 20 seconds and then quiets down and doesn't come back. Doesn't really sound like a belt to me, but I'm no expert.
Need to adjust valves and confirm timing before anything else. Still haven't made it to emissions testing - hopefully today or I might have to shell out another $1.00 for the 3-day restricted registration.
szac
Drives in Mud
Postby DSUZU » Thu Jan 14, 2021 5:38 pm
When you do the timing belt you will have to remove the balancer anyway. As I have suggested for many, if it's accurate, as long as it's off, paint a stripe that goes from the inner part to the outer part (like along the timing groove). This way, if it ever slips, you will know immediately because the lines will no longer be aligned. Dennis
Postby andy_sykes » Thu Jan 14, 2021 7:13 pm
I've never heard of a harmonic balancer squealing. Is that a thing?
andy_sykes
Users browsing this forum: No registered users and 14 guests
