'88 Trooper resto...
Re: '88 Trooper resto...
Postby greasemonkey » Sun Jan 03, 2021 2:23 pm
I wrapped up the exhaust today. I ran it similar to factory but altered the exit. I'm interested in seeing how it performs compared to the very restrictive exhaust that came off.
greasemonkey
Have thanks: 13 times
Postby greasemonkey » Sun Jan 03, 2021 7:49 pm
Finally tackled the rear body mount captured nuts. At first, I cut a hole from the side of the crossmember to see if I could extract the nut and cage from the side. Nope. So then I just cut out the bottom of the piece it's attached to, cut the cage off, extracted the broken off bolt, retapped the threads, hammered the sheet metal flat, recaged the nut, and welded the cage on all 4 sides rather than just 2. Then the whole thing got welded back in. I didn't want to go this route, but it was better than drilling holes through the body from the passenger compartment.
greasemonkey
Postby paulevans76 » Mon Jan 11, 2021 10:30 am
Nice. I went wild cutting holes in the floor and then welding them back up. That undercoat is nasty stuff! Should have done it your way! :blackeye:
MUA5 w/ 3.07's & fixed yoke
Trail armor and Warn XD9000
1994 Samurai - 1.3 FI - OME suspension, 31's, 6.5:1 tcase, 5k milemarker SxS winch, more to come!
Has thanked: 226 times
Have thanks: 185 times
Postby andy_sykes » Wed Jan 13, 2021 2:07 am
Any chance we can get an update? - Sorry, ignore that - my computer showed me I was on the last page, but was in fact still on the first page... That's a bit embarrassing
I'm thoroughly impressed with your progress!
andy_sykes
Has thanked: 2 times
Postby greasemonkey » Fri Jan 15, 2021 8:43 pm
Sadly, I don't have a progress report. I've been working long hours 6-7 days a week and haven't had time to work on the Trooper. Maybe I'll get something done Sunday.
greasemonkey
Postby giusedtobe » Sat Jan 16, 2021 12:59 pm
You are going to have a brand new Trooper when you are done. You have to be the only one that's done a complete frame off restoration of one of these. Very impressed.
giusedtobe
Has thanked: 29 times
Have thanks: 31 times
Postby greasemonkey » Mon Jan 25, 2021 10:37 am
We finally got the body back on the chassis. I've been working the past few weekends but finally had one off and we got to work.
I left the well-stuck factory undercoating alone and sprayed Rusto undercoating over the top of it. In hindsight, I probably should have tried to remove all the factory stuff because it's kind of unsightly with the nice smooth black sprayed over, but it'll do the job. I also didn't want to spend a lot of time under the truck when it was on the cinder blocks and wood, but now that it's back on the chassis, I don't mind rolling around and doing a little more finish work.
Body on but torsion bars loose-
Torsion bars cranked to roughly ride height, and started plumbing the engine bay. Power steering, wiring, and cooling system are done. I'm working on the fuel lines in the engine bay, but my el cheapo flare kit just doesn't make good bubble flares and I don't trust my new hardlines to hold the rubber hoses without a good bead at the end of the tubing. I have a new kit ordered from Cal-Van, it's not the fancy hydraulic kit but looks like it'll work well in tight spaces.
Ignore the disaster in the garage. I made an absolute mess with the undercoating floating all over the place, so once I get the fuel and brake systems functioning, I'll be able to get the truck out of the garage and deep clean it.
greasemonkey
Postby giusedtobe » Mon Jan 25, 2021 7:40 pm
Lol what you call a "Garage Disaster" I call a clean garage. :D
giusedtobe
Postby greasemonkey » Mon Feb 01, 2021 9:19 am
I worked 3 out of the last 4 weekends, so this is my tiny amount of progress. My freshly restored steering shaft:
greasemonkey
Postby greasemonkey » Thu Feb 18, 2021 9:44 pm
Some more progress and some more derailment. Trooper is back up and running well although I need to bleed the brakes for a 3rd time.
I stripped the interior (mostly) and found some rust. The front floor has surface rust that I'm working on wire wheeling and acid treating. The rear had what appeared to be mostly surface rust between the wheel tubs and floor. Further investigation revealed significant rust where the bed floor, wheel tub, and brackets meet. I started drilling out spot welds after stripping the factory seam sealer. I also stripped the underside of the wheel wells and found more rust.
greasemonkey
Postby greasemonkey » Thu Feb 18, 2021 9:52 pm
More pics.
greasemonkey
Postby greasemonkey » Thu Feb 18, 2021 10:09 pm
Last round.
greasemonkey
Postby greasemonkey » Fri Feb 19, 2021 8:22 pm
Tubs are out.
greasemonkey
Postby greasemonkey » Sat Feb 20, 2021 6:47 pm
Bodywork on the tubs today. I can't do much with replacing the metal for the bed floor because I haven't received my weld through primer yet, so I straightened the tubs out and added some patches to the rust holes. Not the prettiest, but these will be coated in undercoating underneath and Lizardskin up top plus carpet, so I didn't grind the welds completely flat. I left a little extra meat for strength.
greasemonkey
Postby greasemonkey » Sun Feb 21, 2021 7:42 pm
Today's body work adventures, in no particular order.
greasemonkey
Postby greasemonkey » Sun Feb 21, 2021 7:46 pm
Last for today.
greasemonkey
Postby greasemonkey » Sun Feb 28, 2021 9:46 pm
I had a whopping one day off, so I didn't get a ton done. I sprayed some weld through primer and cut out a little more rust. I got some carpet samples in the mail from stockinteriors as well.
greasemonkey
Postby BoiseTrooper » Sun Feb 28, 2021 10:02 pm
You are hardcore. I am enjoying following your build.
Great work!
BoiseTrooper
Mi Amigo
Has thanked: 51 times
Postby greasemonkey » Sun Mar 07, 2021 9:10 pm
Weekly update. Metal is replaced, weld through primer sprayed, and tubs reinstalled. In hindsight, I would definitely use some panel bond to put the tubs back in rather than welding. The metal is hilariously thin. It's so thin that even on my welder's lowest setting, it blows holes in the steel without trying. I reckon I figured out why the factory undercoating is freakishly thick underneath the tubs. I have yet to seal the seams up, but maybe this week I'll leave work at a reasonable hour and get something done.
greasemonkey
Postby greasemonkey » Sun Mar 07, 2021 9:15 pm
Then I scuffed everything and sprayed Tamco DTM primer on all exposed steel. I had planned to brush it, but that didn't have the result I wanted, and I sprayed it instead.
For this post the author greasemonkey was thanked by:
Tr00perN00b
greasemonkey
Postby hessmess » Mon Mar 08, 2021 11:29 am
Beautiful work!
88 Trooper (recycled)
https://forum.planetisuzoo.com/viewtopi ... 15&t=81567
89 Pup LS Space Cab, 4X4, 2.25 cat back exhaust system, LSD, Jerry Cam, otherwise stock, painted Oct 2018.
https://forum.planetisuzoo.com/viewtopic.php?t=55081
hessmess
Have thanks: 173 times
Postby DSUZU » Mon Mar 08, 2021 5:23 pm
Great work and thorough build. I love seeing this kind of restoration. Dennis
Has thanked: 284 times
Have thanks: 977 times
Postby greasemonkey » Sun Mar 28, 2021 7:46 pm
Weekend update. Rust is gone, floors are scrubbed and scuffed, seam sealer is applied, and Lizard Skin sprayed. I've never used the stuff but wasn't impressed after the first coat. After coats 2 and 3, I'm a fan. I'm not sure why they call it black because it's definitely not black.
greasemonkey
Postby greasemonkey » Sun Mar 28, 2021 7:52 pm
"Brushable" seam sealer is, well, not very brushable. I tried but found I got a much better result smearing it with my finger. So go easy on my sloppy application. It's all covered up anyway.
greasemonkey
Postby greasemonkey » Sun Mar 28, 2021 7:58 pm
Last round.
dankly1
greasemonkey
Users browsing this forum: blitzen and 16 guests
