91 Storm Trooper rebuild project
Postby Docloucks » Sat May 01, 2021 10:14 am
Ok so here I go. Had an ‘88 a ‘94 and a ‘98 over the years. About to dive into my new ‘91 that I picked up in Nor Cal for $2k with a bad rod knock and no power but still moving. Clean body, nice 2” lift and great rubber.
Specs: ‘91 Trooper with 4 cyl 4ze1 and manual transmission. Plan is to start pulling the motor this weekend and get it up to Reno to Shawn Anthony for a complete rebuild. Lots of “Might as Wells” to happen. Will pull the tranny and have a local shop go through it. Definitely a new clutch and then put it all back together.
I have reasonable diy mechanical skills and great internet. Lol. I have pulled and a replaced an engine in an old CJ5 back in college 30-years ago. I’m less flexible but more patient now...
Following an old Chilton removal instruction and extra tips gathered from the forum and YouTube.
Fingers crossed! Will post updates and pics as I go for those interested. Tips and advice welcomed!
Docloucks
Re: 91 Storm Trooper rebuild project
Postby Docloucks » Sun May 02, 2021 5:22 pm
Weekend 1 up; radiator, shroud and fan out, all the electrical and vacuum labeled and disconnected, exhaust tailpipe pick up removed, PS disconnected, Next weekend I'll borrow a cherry picker and go for the pull. Leaving the Itec on. Will wrestle the tranny bolts and cross my fingers. Working slow and methodically with only a few hours each day per weekend. Final removal will determine if I have the balls to attempt re-install. Like the built not bought approach... fingers still crossed
Docloucks
Postby BoiseTrooper » Mon May 03, 2021 1:40 am
Nice rig! Welcome!
I recently put a 4ze1 crate motor in my '89.
If you are going for a full rebuild anyway, I think it is easier to pull the head and itec combo as a complete unit. That way you don't have to try to get to the intake bolts underneath the plenum on the itec. You can just take the whole head off and the itec comes with it. It makes pulling the block easy after the head/itec is off. I have pics of pulling the old motor on my Project Thunderbolt thread.
You can do it!
If you have access to a lift, I found I was able to stand under the transmission and reach up on either side like I was giving it a hug and was able to reach those bolts pretty well. Otherwise, the trick of removing the motor mounts and dropping the engine and transmission tilts down a couple inches gives you more space. (it rests on the crossmember) J5 has a vid on youtube on it.
Kind regards,
-BoiseTrooper
For this post the author BoiseTrooper was thanked by:
Docloucks
BoiseTrooper
Has thanked: 47 times
Postby giusedtobe » Mon May 03, 2021 7:46 am
Nice! From your college timeframe I think we are ~ the same age. Not trying to take $ away from Shawn but you can rebuild it yourself if you have a reasonable machine shop in the area. I am not as flexible as I once was either but managed all the work alone. I had done a fair amount of peripheral auto work; brakes, water pumps etc. but had never dug into the guts of a motor. With the help of people here I rebuilt mine. I have a thread called 2.6 rebuild if you are interested.
Alan
For this post the author giusedtobe was thanked by:
BoiseTrooper
giusedtobe
Has thanked: 29 times
Have thanks: 28 times
Postby Docloucks » Mon May 03, 2021 11:03 am
Baby steps... I'm going to leave the internal rebuild to the pros this time and see if I can try and not screw up the rest, lol. Lots of knowledge out there to help me through it hopefully. Now I get to do my day job all week and prep for next weekend
giusedtobe wrote:Nice! From your college timeframe I think we are ~ the same age. Not trying to take $ away from Shawn but you can rebuild it yourself if you have a reasonable machine shop in the area. I am not as flexible as I once was either but managed all the work alone. I had done a fair amount of peripheral auto work; brakes, water pumps etc. but had never dug into the guts of a motor. With the help of people here I rebuilt mine. I have a thread called 2.6 rebuild if you are interested.
Alan
For this post the author Docloucks was thanked by:
BoiseTrooper
Docloucks
Postby mudoilngears » Mon May 03, 2021 12:33 pm
Docloucks wrote:Baby steps... I'm going to leave the internal rebuild to the pros this time and see if I can try and not screw up the rest, lol. Lots of knowledge out there to help me through it hopefully. Now I get to do my day job all week and prep for next weekend
I'd make sure the pros are pros before sending it to the pros. If you take my meaning...
Build in progress...
mudoilngears
Has thanked: 19 times
Have thanks: 187 times
Postby giusedtobe » Mon May 03, 2021 4:06 pm
Agree. You do it yourself then you know its done right.
giusedtobe
Postby paulevans76 » Tue May 04, 2021 4:42 pm
That looks like the one that had a build thread on here some years ago. https://www.planetisuzoo.com/viewtopic.php?f=1&t=74710 The owner dumped ton of time and money into it and then sold out of isuzu after getting frustrated with it and his other projects. If that is the same rig, it looks like it was partially parted out. I don't think the photos still work but it was same very nice white with round eye grill, but the owner had black interior done. The wheels and tires look the same too.
MUA5 w/ 3.07's & fixed yoke
Trail armor and Warn XD9000
1994 Samurai - 1.3 FI - OME suspension, 31's, 6.5:1 tcase, 5k milemarker SxS winch, more to come!
Has thanked: 224 times
Have thanks: 185 times
Postby Docloucks » Tue May 04, 2021 5:07 pm
Nope. Similar but not the same one. Carfax mileage and owner history doesn’t add up. Plus it’s got stock brown interior. The guy I got it from did switch out the grill and lights to the round but have tons of paperwork and receipts. Great recall though. I’m impressed
Docloucks
Postby mudoilngears » Tue May 04, 2021 7:14 pm
Bart's Trooper was the first thing I though of when I saw this.
mudoilngears
Postby Docloucks » Tue May 04, 2021 7:40 pm
well hopefully Bart's was badass and will lend some cosmic force to mine being that it is Star Wars day...
Docloucks
Postby Docloucks » Sun May 09, 2021 10:12 am
Labeling, bagging and tagging.... boy there are a lot of hoses, electrical connections and vacuum pieces. Praying my tape labels, videos and pics help me figure out how to put it all back together! I get the strange feeling I will need resources to figure the puzzle back out, lol.
Docloucks
Postby giusedtobe » Sun May 09, 2021 6:10 pm
Take lots of pictures and label like you are doing and you will find it surprisingly easy. If you lose a label and forget you can find it here in photos or just ask and someone will know.
giusedtobe
Postby Tentin » Sun May 09, 2021 6:58 pm
Yep any organization you do now will pay off in the long run. Labeled ziploc bags for bolts and smaller pieces helps too
1995 Isuzu Pickup 4WD aka Suzie Q. 3" lift, 32" A/T's
1998 Isuzu Amigo 4WD aka Smeagol The Amigo. 2" Lift, 31" A/T's
Tentin
Mi Amigo
Have thanks: 20 times
Postby Docloucks » Sun May 09, 2021 10:17 pm
Ziplock bags with pre-printed labels tape on hoses and ends with corresponding numbers etc.
biggest current issue is wrestling with a couple mechanical issues like getting the fricking starter out as well as the ac compressor off...!
I know that come rebuild it’s the block and the head that go to the shop so I’m ok taking off extra items during disassembly knowing they either come off while in the engine compartment or off on the engine stand later.
Slow, gradual, no rush steady progress is the mantra. It’s supposed to be FUN is what my wife keeps telling me and I want the fun to last for a while, lol
Docloucks
Users browsing this forum: No registered users and 4 guests
