Weber carburetor rant
Postby steve mortillaro » Tue Mar 09, 2021 6:41 pm
My '87 Toyota has a Weber carburetor. It's been great, as long as its in tune (otherwise it likes to diesel bit). It's not that old- maybe has about 15-20k miles on it. The throttle shaft started sticking, so I ordered a new throttle shaft bearing kit from Pegasus Auto- who is great and had the part in about 2 days. So I go to replace the old nylon bushings with real metal bearings. When I went to unscrew the throttle plate, I noticed that the heads of the screws are a little bit wallowed out. Well, I unscrewed them and what do you know? one of them pulled the threads out of the throttle shaft. This was a new carburetor to me that I purchased from Redline, mfg. in Spain- real Weber apparently, but when the throttle plate was screwed on, it was cross threaded. They just jammed it in there- kept going and forced it in.... Big suck!
Now I'm waiting for a new throttle shaft and will probably keep the old one and tap it just a little bigger as a spare
1986 Trooper II- My old beater- gone, but missed
1990 Trooper XS v6- Best vehicle I ever owned
1991 Trooper SE v6- The new and ongoing project
1987 Toyota 4x4 pickup- Farm truck
2000 Ford E-250 xl- work van
steve mortillaro
Has thanked: 4 times
Have thanks: 5 times
Re: Weber carburetor rant
Postby Ed Mc. » Tue Mar 09, 2021 11:17 pm
Man, they just don't make 'em like they used to! I expect Weber quality control in the Good Old Days was much better. Very frustrating to find stuff that they couldn't even bother to screw together right at the factory.
Years ago I had '72 Datsun 521 1600 pickup, and I ended up finding a Weber single-sidedraft carb and intake for that engine. It really flew! I was blowing off Olds Cutlass V6 Sports Coupes at the stoplights! It didn't have the cross-over manifold, so didn't carburate that smoothly at low speeds. But it had a killer top end! The little L-16 would just scream. I eventually got a 2-bbl progressive carb and replaced the Weber. It still ran pretty good and idled real nice. Now, if I had had a hot cam, header, and Twin DCOEs on that, I would have been in 7th Heaven!! :mrgreen:
G'luck with your cranky Weber!..........ed
'90 3.4 Troop LS;
Yes, I am a Trooper-Holic!!!
Keep On Troopin' !
Ed Mc.
Have thanks: 405 times
Postby DSUZU » Wed Mar 10, 2021 5:45 pm
steve mortillaro wrote: When I went to unscrew the throttle plate, I noticed that the heads of the screws are a little bit wallowed out
Many manufacturers used to "stake" throttle and choke plate screws to keep them from coming loose. The service procedure was to replace shaft and screws. Dennis
Has thanked: 284 times
Have thanks: 977 times
Postby steve mortillaro » Thu Mar 11, 2021 6:37 am
That makes sense. Perhaps also why the bearing kit comes with new screws. I think I'll try purple loctite on the screws instead of peening or damaging the new screw threads. Hope the purple stuff can handle non-ethanol 87 octane. A quick web search tells me people are using this on throttle plate screws.
steve mortillaro
cron
