Advice on bad braking shudder - Dennis?
Postby Oro » Fri Jul 31, 2020 4:46 am
OK, so me thinking I'm all that great, maybe not...
My ex-neighbor with the Subaru B9/Tribeca texted, and it was shuddering badly. Talked about in May:
https://www.planetisuzoo.com/viewtopic. ... 4&t=142911
I drove it tonight and it's only when braking between 65 and 55. And it's fairly rough. General shaking that is the whole car, not just pulsing through the brake pedal/steering. Otherwise, driving and accelerating or braking at all other speeds, the car drives like I left it in May, VERY nicely. The rotors were turned, and I put in new ceramic pads. I bedded them together with a controlled series of panic stop, per good practice, so that shouldn't be an issue. Any other speeds, it's smooth as silk, brakes/steers/etc. lovely. Frankly, better than it should at that mileage!
I am thinking it must be a lower control arm bushing? I recall when I was under it inspecting it in general, I was questioning the right front rear control arm bushing, but then I went on-line and looked at pictures of replacement bushings and they had similar voids. The car has 221k on it so I can't imagine it NOT needing some control arm work by that point so I'm thinking that. I of course can jack it up and look again, I'm just spit-balling so I refine my thinking before doing that in a few days.
I have to say wrt the Tribeca, I'm impressed. My neighbor, who doesn't drive much any more, has a 2017 Outback ltd/loaded model with 13k on it; I drive it often (I did today) and it's a nice car. This 2006 Tribeca is very smooth, very well built, stacks up well. I gather the Tribeca was actually positioned at the top of the Subaru line at the time but just didn't catch on? I have driven other Subarus from that period and they don't have this level of refinement and build quality (new ones certainly do; not bashing the brand).
Oro
Has thanked: 16 times
Have thanks: 128 times
Re: Advice on bad braking shudder - Dennis?
Postby DSUZU » Sat Aug 01, 2020 8:19 am
Yes, check those control arm bushings. I'm not all that familiar with the Tribecas, but a lot of the Subaru components are the same. My daughters 2002 Forester (240K plus miles now) had some shudder issues. That turned out to be tires. It also has a clunk when you first put it in reverse. I suspect that may be the bad (loose) lower control arm bushing on the right front. Best I can suggest is get all 4 wheels off the ground and check for movement or play in all axis. Try moving the LCAs back and forward with a pry bar while watching for movement. There is (again - Tribeca vs what I have) a carrier bearing on the drive shaft, might check that too. Dennis
Has thanked: 277 times
Have thanks: 888 times
Postby Oro » Thu Aug 06, 2020 5:53 pm
Yep, right front control arm bushing.
I put that side on a ramp so as to torque the suspension a little. That made the tear really obvious, other side is still ok but some cracking. I'll buy two bushings and do that side for her, and have one on hand if it starts to show any problems - probably will soon. ;)
Question: Look at the end of the arm - am I going to be able to press that out easily? I am worried as the arm itself doesn't surround the bushing housing fully, only 1/2 way. I worry that's going to make it slip without all-around support; I have never tried pressing a bushing/bearing etc. with such little support.
Oro
Postby DSUZU » Thu Aug 06, 2020 7:32 pm
IIRC, the entire arm assemblies are inexpensive. I haven't replaced any Subaru bushings yet. As I said, my daughter's 02, I can take a bar and slide the arm back a forth a little bit. Other than the initial clunk, there has been no handling or wear issues. Dennis
Return to Other Vehicles
Users browsing this forum: No registered users and 12 guests
