Swingdown Tailgate mod to 1st Gen Amigo
Postby Ssiggy » Sat Aug 29, 2015 3:26 pm
James​y asked me realllllly nicely to post info on my 1st Gen Amigo tailgate conversion on my wife's beast, Esmerelda. I briefly discussed it on the Planet, but here it is in detail.
Get some 1st gen Rodeo hinges and cables at the junkyard. If you're going to use the Amigo tailgate, you will not need the torsion spring that is attached to the donor Rodeo's tailgate.
The key to this thing is temporarily mounting the hinges to the truck and tailgate while it's closed and latched using the existing side hinges. You must do this to properly align the latch mechanism.Image
If your truck does not have a body lift, you may need to remove the bumperettes first. I found that I could not properly drill holes for the hinge mounts all the way through the body for the hinge mounts because I did not have a super long drill bit and that positioning the hinges where the Rodeo has them would interfere with the two rear body mounts. So, I used rivnuts into the body panel. Jerry cautioned me beforehand that I may need to reinforce the sheet metal where the hinges mount, but inspection of the Rodeo at the junkyard showed that the sheet metal at that location was the same on the two vehicles. In addition, it's really the straps that hold the tailgate up, the hinges are just a pivot point.
So mount your hinges temporarily without removing the old hinges, or at least drill the holes. I did reinforce the tailgate sheet metal with fender washers, because that section is just a single layer of sheet metal. ImageImage
I mounted the hinges, then removed the original hinges. I also had to cut the sliding track mechanism that limits the side tailgate travel. Then I locate some spots to hang the straps, once again using fender washers behind the sheet metal.ImageImageImageImage
In my case, the latch mechanism worked perfectly. The tailgate is only latched from the one side, but it is very secure. I felt like the spare tire would make it too heavy, so I removed it. I suppose using the original Rodeo torsion spring on the tailgate might fix that. I chose not to mount it since I was using the Amigo tailgate, not the rodeo one.
The conversion was very straightforward, no surprises. It works perfectly. I can stand on the tailgate with no issues. It should allow a hard top or soft top to work without problems.
THERE IS NO DANA ONLY ZUUL!
Well, there IS a Dana-- a Dana 44
'99 Amigo 3.2 AT 4WD - 2" body lift, 3" suspension lift, revos, Aussie Locker front, sliders,vinyl wrap, VX seats, OME 912 springs - Rolled but running
'92 Amigo (from Shaggy) future project
90 Amigo 2.6 5-sp 4WD - 3" body lift, 3" suspension lift, Calmini uppers, Calmini headers, Delta cam, Jet chip, sliders, revos, Warn brush guard/winch mount, ProMark 12K winch, snakeskin wrap
For this post the author Ssiggy was thanked by:
Ssiggy
Has thanked: 21 times
Have thanks: 64 times
Re: Swingdown Tailgate mod to 1st Gen Amigo
Postby DSUZU » Sat Aug 29, 2015 4:46 pm
Thanks for posting. I don't have an Amigo or a Rodeo (that I know of :D), but it is always nice to see a "How you do it" posting. When we had our Rodeo, my wife always hated the drop down tailgate. She said it made it hard to get groceries in and out (spoiled by the top hinged minivan doors). Myself, I would prefer the fold down. Dennis
Has thanked: 284 times
Have thanks: 977 times
Postby tylerruinstrucks » Wed Apr 28, 2021 1:43 pm
Thinking about doing this with my 89 Amigo. Bummed that the photos no longer work on this post, but think it seems pretty straightforward. I suppose I would also install the Rodeo swinging tire carrier?
tylerruinstrucks
Postby DSUZU » Wed Apr 28, 2021 8:51 pm
The Rodeo tire carrier is mounted to serious mounts made into the left rear of the body. You might be able to cut them out. Dennis
Users browsing this forum: Google [Bot] and 8 guests
cron
