Help!!! Transmission guys
Postby 99_trooper » Fri May 07, 2021 7:31 pm
Ok, new guy here.
My questions are about transmission. On one of the Facebook Isuzu groups. One of the guys was saying that bell housing on 2.5 & 2.6 are the same as the GM 60° V6, ok. But he also stated that the 3.2 & 3.5 also shared the same 60° V6 bolt pattern. It was also stated that any transmission from a GM 60° V6 will bolt up. I'm still learning my way around this website.
So is this true?
Thanks
Frazier
My 1999 Trooper codes:
G80 =LSD
S7C =4.30 Gear ratio
V05 =HD radiator
7EX =Shift on the FLY
YM4 =Laminated tinted glass
6MK =Doors mirrors folding w/DEF
RMQ = 4l30 A/T weak tranny [w/ power/winter buttons] & TOD
1st mod: manual hubs
Now for a funny one
8AA =GOOD QUALITY ethylene glycol AntiFreeze
So do you get so so AntiFreeze w/other codes
This one I can't find. Just under the Vin# is
M.D. (UBS7VF) then (AI/JJ) ???
Does anybody know what this means?
Thanks
Frazier
99_trooper
Re: Help!!! Transmission guys
Postby DSUZU » Fri May 07, 2021 9:21 pm
There is no "2.5". You may be thinking about the 2.3 and 2.6. Those DO share the same "bell housing" pattern, but it is nothing like a GM 60 degree V-6. It is my understanding that the 3.2 bell housing pattern MAY be the same as the GM 60 degrees. IIRC, there is a place on each side where there are two bolt holes and one set fits the 3.2 and (again IIRC) the other hole fits the GM pattern. Hopefully, someone else can add further details about the GM / 3.2 bell housings. Dennis
99_trooper
Has thanked: 284 times
Have thanks: 977 times
Postby Shawn Anthony » Sat May 08, 2021 1:50 am
The 3.2L & 3.5L Isuzu V6 share the same engine block. these engines fit the GM 60 degree v6 bolt pattern. This pattern is different than the 60 degree 4 cylinder pattern. Thus the 2.3 & 2.6L Isuzu 4 cylinders which share the same engine block & will not bolt to the V6 transmissions.
For this post the author Shawn Anthony was thanked by:
99_trooper
Shawn Anthony
Has a Trail Truck
Have thanks: 33 times
Users browsing this forum: No registered users and 24 guests
