2.6 4ZE1 CALIFORNIA vac diagram (Solved)
Postby TroopDawg » Thu Apr 08, 2021 10:15 pm
For the love of God, please!!! How do i plumb in the blue (electric powered) vaccum swith/selenoid...
1991 isuzu trooper 2.6 4ze1 MUA5
I havent seen it in a single video. I did a full body swap so please dont ask me to refer to the hood diagram :( its an 85 body on a 91 frame.
Everything was connected before i did the swap so i know i have everyrhing.
The before pics i took do me no justice when it comes to using them now.
I am good with the names, shapes, locations and descriptions of parts, so it would help if someone could do a worded step by step diagram that follows the order of operation. (Hip bone is connected to the thigh bone) type write-up lol.
What does this sensor actually do? Im in california soni have to pass smog, if i can bypass it somehow and stay legal, let me know.
Thank you so much ahead of time
TroopDawg
Has a Trail Truck
Has thanked: 118 times
Have thanks: 8 times
Re: 91 trooper CALIFORNIA vac diagram!
Postby TroopDawg » Thu Apr 08, 2021 10:40 pm
If it helps.... the vac valve/selenoid is colored blue, i know it sits on top of the motor near the intake. It has 3 vac ports and i know the port on one end of it points down... yet i have no idea where any of the 3 ports lead to.
I think i can handle the rest of the diagram on my own once i get past this part
TroopDawg
Has a Trail Truck
Postby TroopDawg » Thu Apr 08, 2021 10:45 pm
This is the part
TroopDawg
Has a Trail Truck
Postby TroopDawg » Fri Apr 09, 2021 12:37 am
This is the only installed example photo i can find. Its a snapshot from a video of an idling trooper on youtube. This valve is right next to the coil... i just dont know where the vac lines lead
TroopDawg
Has a Trail Truck
91 trooper EGR vac/solenoid diagram
Postby TroopDawg » Fri Apr 09, 2021 1:07 am
How is the blue EGR vac selenoid installed? How is it conmected via vac lines?
TroopDawg
Has a Trail Truck
Postby Shawn Anthony » Fri Apr 09, 2021 3:18 am
This is your EGR duty solenoid.
One port attaches to the intake manifold. The other port runs to your vacuum regulator after it tee off into a parallel circuit. The parallel circuit runs to the V.S.V. control switch port. At this point the EGR valve is connected to the other port of the the V.S.V. switch completing the EGR validation system
For this post the author Shawn Anthony was thanked by:
Enemigo
Shawn Anthony
Has a Trail Truck
Have thanks: 32 times
Postby TroopDawg » Fri Apr 09, 2021 8:26 am
Thank you so much! That helps alot! Im just having trouble figuring out WHAT port on the solenoid goes to WHAT port on the egr.
TroopDawg
Has a Trail Truck
Postby TroopDawg » Fri Apr 09, 2021 8:28 am
When u say “tees off”... do you mean it tees off by use of the “f connector” or the blue thermal vac switch?
TroopDawg
Has a Trail Truck
Postby TroopDawg » Fri Apr 09, 2021 8:34 am
And you mentioned 2 of the three ports. From the pics i see of this part online... it looks like there is some sort of plastic vent cap that goes on the bottom port? Mine is gone or non existent. Is the furthest bottom port on the solenoid a vent?
TroopDawg
Has a Trail Truck
Postby TroopDawg » Fri Apr 09, 2021 8:50 am
Maybe this helps
TroopDawg
Has a Trail Truck
Postby Tentin » Fri Apr 09, 2021 1:44 pm
Here's mine for what its worth, from a 95 CA 4ZE1 pickup. Doesn't have that 3rd port
1995 Isuzu Pickup 4WD aka Suzie Q. 3" lift, 32" A/T's
1998 Isuzu Amigo 4WD aka Smeagol The Amigo. 2" Lift, 31" A/T's
Tentin
Rodeo King
Have thanks: 25 times
Postby TroopDawg » Fri Apr 09, 2021 6:23 pm
I think that diagram will do!!! Thank u
TroopDawg
Has a Trail Truck
Postby Shawn Anthony » Fri Apr 09, 2021 8:22 pm
TroopDawg wrote:Thank you so much! That helps alot! Im just having trouble figuring out WHAT port on the solenoid goes to WHAT port on the egr.
its a simple on/off switch thus, it doesn't matter.
Shawn Anthony
Has a Trail Truck
Postby TroopDawg » Fri Apr 09, 2021 8:33 pm
Is there a way ti bypass it without effecting the egr?
TroopDawg
Has a Trail Truck
Postby TroopDawg » Fri Apr 09, 2021 8:42 pm
And even if it doesnt matter, its still gonna lill me to not know exactly where the ports lead to lol
TroopDawg
Has a Trail Truck
1991 tooper california diagram on hood
Postby TroopDawg » Fri Apr 09, 2021 8:48 pm
Can someone please take a pic of the diagram on their hood?! It HAS to be a 91 4ze1 IN CALIFORNIA. It seems like something has changed every year with the vac lines. Finding a clear pic of the diagram is impossible. The autozone diagrams look blurry
TroopDawg
Has a Trail Truck
Re: 1991 tooper california diagram on hood
Postby Enemigo » Fri Apr 09, 2021 10:06 pm
How many different threads are you going to start about this same issue?
1999 Amigo - Sold
1999 Trooper. Mods TBD
Enemigo
Has thanked: 4 times
Have thanks: 30 times
Postby TroopDawg » Fri Apr 09, 2021 10:24 pm
Until i feel ive worded it correctly i guess. Thanks for askin’!
And this post isnt asking for any specifics or help like the other two..
Just a photo.
Hope ive answered your question better than you have mine
TroopDawg
Has a Trail Truck
Postby TroopDawg » Fri Apr 09, 2021 10:30 pm
Oh and if you can even FIND a thread that already exist on the part and subject im posting about, could you so kindly post it in your next reply?... becaus if not... im sure somoene will be very grateful that i DID ask 3 different ways here on planetisuzu so they could easily access the info for themselves in the future. (Via my other two threads)
TroopDawg
Has a Trail Truck
Postby Enemigo » Fri Apr 09, 2021 10:43 pm
I'd love to help you out, but I can't.
1999 Amigo - Sold
Enemigo
Postby TroopDawg » Fri Apr 09, 2021 10:48 pm
And that answer there is MAINLY why ive posted 3 different threads on the same topic. Thanks tho. Have a good night. Be safe.
Anyone else?
TroopDawg
Has a Trail Truck
Postby Enemigo » Fri Apr 09, 2021 10:54 pm
Now I'm curious though, exactly how does one identify a California Trooper? There could be one sitting in a yard by me right now, but I wouldn't know.
1999 Amigo - Sold
Enemigo
Postby TroopDawg » Fri Apr 09, 2021 11:13 pm
California equipped. Smog components. Emmisions BS. Youd know the difference between a fed and cali equiped trooper if they were side by side. They all look the same in a yard with the hood down.
TroopDawg
Has a Trail Truck
Postby TroopDawg » Fri Apr 09, 2021 11:14 pm
And if it has a cali license plate that was ORIGINALlY registered IN california when it was first sold off the lot in 1991
TroopDawg
Has a Trail Truck
Postby TroopDawg » Fri Apr 09, 2021 11:19 pm
Oh and not to mention.... our troopers in Cali are usually rust free and in prime shape. Thats the easiest way to tell
TroopDawg
Has a Trail Truck
Users browsing this forum: Google [Bot] and 23 guests
