rear disc brake caliper bracket bolt size? !
Posted:
Thu Oct 29, 2020 7:06 pm
by Sh_YVR
00RODEO4wd 3.2
Does anyone know the part no(s) of the 17mm caliper bolt that holds the caliper bracket ?!
(after a brake job, one came off ; luckily noticed before it grinded the rim too much.
Re: rear disc brake caliper bracket bolt size? !
Posted:
Fri Oct 30, 2020 3:28 am
by Buster28
Sh_YVR wrote:00RODEO4wd 3.2
8-97351-108-0 $2.64 USD
Posted:
Fri Oct 30, 2020 3:46 am
by Sh_YVR
thanks buster...
any suggestions on an e-store ? kinda hard to figure out who actually keeps it.. I'm close to MN.grandforks..
I also may try the HONDA dealer here..
Posted:
Fri Oct 30, 2020 4:43 am
by Buster28
Sh_YVR wrote:thanks buster...
The caliper bolt was used from 1994 to 2002 with Honda and Acura so a local dealer may have one in stock.
The parts stores and amazon sell caliper hardware kits that include these bolts and the pins, the trick is to find the correct ones for your truck. It is 12mm x 27mm and I think the pitch is 1.25mm
Posted:
Sun Nov 01, 2020 2:24 am
by Sh_YVR
Do you/anyone know what the torque should be ?
(btw - it has held true for years now... I would say 1/4-1/3 of the time I get service they create a new problem - it must be nightmare servicing a late model vehicle)
Posted:
Sun Nov 01, 2020 7:05 am
by Buster28
Caliper Bracket Bolt torque
Posted:
Sun Nov 01, 2020 7:29 am
by Sh_YVR
thanks - that tells me the guy wasn't even close...(helped redo it/was using a standard socket wrench)
Posted:
Sun Nov 01, 2020 7:34 am
by Buster28
Sh_YVR wrote:thanks - that tells me the guy wasn't even close...(helped redo it/was using a standard socket wrench)
This may wrong, I just found another image with a different spec. Will sort it out and get back to you.
Posted:
Sun Nov 01, 2020 7:49 am
by Buster28
This is a rear 4WD 2000 Rodeo/Amigo caliper. The previously posted spec came from the same FSM and was for the front caliper. Makes no sense because the bolts are the same.
Posted:
Sun Nov 01, 2020 8:10 am
by Sh_YVR
well I think he prob put it at 50-80 so way off... (based on watching) I'm sure of it was 100 never would have happened.
Posted:
Sun Nov 01, 2020 9:03 am
by Buster28
I have used a 4ft piece of pipe on a breaker bar to get them loose so the bolts are industrial strength quality.
They don't need to be very tight, just a little blue thread locker to keep them tight.
Posted:
Sun Nov 01, 2020 11:25 am
by Buster28
Btw. are you aware that the two caliper slide pins/bolts are not the same. The top one is the Guide bolt and the bottom one is the Lock bolt.
The Guide Bolt has two flats and the head has the letter G stamped on it.
The Lock Bolt is round.
Torque: 44 N·m (32 lb ft)
Posted:
Sun Nov 08, 2020 12:12 am
by Sh_YVR
is there anything special about the washer ?( on the bracket) ... I found new bolts but they don't have the washer - presuming the original one also fell out.
Posted:
Mon Nov 09, 2020 6:02 am
by Buster28
Any 12mm flat washer that has the same thickness (more or less) should work, use the washer on the other bolt as a guide.
