rear disc brake caliper bracket bolt size? !
Postby Sh_YVR » Thu Oct 29, 2020 7:06 pm
00RODEO4wd 3.2
Does anyone know the part no(s) of the 17mm caliper bolt that holds the caliper bracket ?!
(after a brake job, one came off ; luckily noticed before it grinded the rim too much.
Sh_YVR
Has a Trail Truck
Has thanked: 2 times
Re: rear disc brake caliper bracket bolt size? !
Postby Buster28 » Fri Oct 30, 2020 3:28 am
Sh_YVR wrote:00RODEO4wd 3.2
8-97351-108-0 $2.64 USD
2002 Rodeo Sport 4X4 3.2L V6
2020 Jeep Wrangler 2dr 4x4 3.6L V6
2000 Cadillac ETC 4.6L V8
1991 Cadillac Allante 4.5L V8
Buster28
4L30E Guru
Have thanks: 1249 times
Postby Sh_YVR » Fri Oct 30, 2020 3:46 am
thanks buster...
any suggestions on an e-store ? kinda hard to figure out who actually keeps it.. I'm close to MN.grandforks..
I also may try the HONDA dealer here..
Sh_YVR
Has a Trail Truck
Postby Buster28 » Fri Oct 30, 2020 4:43 am
Sh_YVR wrote:thanks buster...
The caliper bolt was used from 1994 to 2002 with Honda and Acura so a local dealer may have one in stock.
The parts stores and amazon sell caliper hardware kits that include these bolts and the pins, the trick is to find the correct ones for your truck. It is 12mm x 27mm and I think the pitch is 1.25mm
Sh_YVR
Buster28
4L30E Guru
Postby Sh_YVR » Sun Nov 01, 2020 2:24 am
Do you/anyone know what the torque should be ?
(btw - it has held true for years now... I would say 1/4-1/3 of the time I get service they create a new problem - it must be nightmare servicing a late model vehicle)
Sh_YVR
Has a Trail Truck
Postby Buster28 » Sun Nov 01, 2020 7:05 am
Caliper Bracket Bolt torque
Buster28
4L30E Guru
Postby Sh_YVR » Sun Nov 01, 2020 7:29 am
thanks - that tells me the guy wasn't even close...(helped redo it/was using a standard socket wrench)
Sh_YVR
Has a Trail Truck
Postby Buster28 » Sun Nov 01, 2020 7:34 am
Sh_YVR wrote:thanks - that tells me the guy wasn't even close...(helped redo it/was using a standard socket wrench)
This may wrong, I just found another image with a different spec. Will sort it out and get back to you.
Buster28
4L30E Guru
Postby Buster28 » Sun Nov 01, 2020 7:49 am
This is a rear 4WD 2000 Rodeo/Amigo caliper. The previously posted spec came from the same FSM and was for the front caliper. Makes no sense because the bolts are the same.
Buster28
4L30E Guru
Postby Sh_YVR » Sun Nov 01, 2020 8:10 am
well I think he prob put it at 50-80 so way off... (based on watching) I'm sure of it was 100 never would have happened.
Sh_YVR
Has a Trail Truck
Postby Buster28 » Sun Nov 01, 2020 9:03 am
I have used a 4ft piece of pipe on a breaker bar to get them loose so the bolts are industrial strength quality.
They don't need to be very tight, just a little blue thread locker to keep them tight.
Buster28
4L30E Guru
Postby Buster28 » Sun Nov 01, 2020 11:25 am
Btw. are you aware that the two caliper slide pins/bolts are not the same. The top one is the Guide bolt and the bottom one is the Lock bolt.
The Guide Bolt has two flats and the head has the letter G stamped on it.
The Lock Bolt is round.
Torque: 44 N·m (32 lb ft)
Buster28
4L30E Guru
Postby Sh_YVR » Sun Nov 08, 2020 12:12 am
is there anything special about the washer ?( on the bracket) ... I found new bolts but they don't have the washer - presuming the original one also fell out.
Sh_YVR
Has a Trail Truck
Postby Buster28 » Mon Nov 09, 2020 6:02 am
Any 12mm flat washer that has the same thickness (more or less) should work, use the washer on the other bolt as a guide.
Buster28
4L30E Guru
Users browsing this forum: justjordan and 5 guests
