Bolting vs. Welding sliders
Postby NAES » Fri Dec 20, 2019 10:44 pm
Hey everyone. I did a search and didn't find the answer I was looking for. I will be making a set of sliders for my '90 in the not too distant future and had a questions about mounting them. Most everything I see and read is welded to the frame but I can also see how this could be an issue down the road either as my tastes change or I continue building my truck. I would hate to weld them up and then do a body lift later on, etc.
The idea of welding or bolting the sliders in seems like it would put a ton (literally) of torsional stress on the frame going over anything rocky and wasn't sure the frame could handle it without damage. Maybe I'm overthinking it, maybe not.
If you guys don't mind chiming in, I would appreciate any input before I go at it.
NAES
NAES
Mi Amigo
Re: Bolting vs. Welding sliders
Postby mudoilngears » Fri Dec 20, 2019 11:48 pm
NAES wrote:Hey everyone. I did a search and didn't find the answer I was looking for. I will be making a set of sliders for my '90 in the not too distant future and had a questions about mounting them. Most everything I see and read is welded to the frame but I can also see how this could be an issue down the road either as my tastes change or I continue building my truck. I would hate to weld them up and then do a body lift later on, etc.
NAES
I avoid welding on frames as much as possible. I would bolt them.
1998 Rodeo LS 4x4 4JB1-TC Diesel Swap, Moog CC247 coils, more mods to come!
Build in progress...
mudoilngears
Has thanked: 19 times
Have thanks: 188 times
Postby shaggydoink » Sat Dec 21, 2019 10:44 am
NAES wrote:The idea of welding or bolting the sliders in seems like it would put a ton (literally) of torsional stress on the frame going over anything rocky and wasn't sure the frame could handle it without damage. Maybe I'm overthinking it, maybe not.
I've had welded sliders on my 1990 Trooper for years and done some pretty extensive off-road travel. While I can't say there has been zero impact to the frame, I can say that there has not been any noticeable damage... i.e: cracks, obvious warps, etc. As I'm sure you saw in your reading there is a lot of debate about weld vs. bolt on, in your case as you think your build might continue to evolve I can see the benefit in going the bolt on route.
Good luck!
p.s: oh, and post up a picture when you're done! :thumbup:
Has thanked: 807 times
Have thanks: 414 times
Postby paulevans76 » Sat Dec 21, 2019 10:49 am
Most will be welded on. You can always cut them off later if needed. A half decent design either way should add strength and structural rigidity to the frame.
MUA5 w/ 3.07's & fixed yoke
Trail armor and Warn XD9000
1994 Samurai - 1.3 FI - OME suspension, 31's, 6.5:1 tcase, 5k milemarker SxS winch, more to come!
Has thanked: 225 times
Have thanks: 185 times
Postby Skeletor » Sat Dec 21, 2019 8:52 pm
paulevans76 wrote:Most will be welded on. You can always cut them off later if needed. A half decent design either way should add strength and structural rigidity to the frame.
do it both ways....bolt'em....and spot weld 'em in...
1990 Trooper V6 (sold) 1991 Trooper LS V6, (sold) 1990 Trooper V6, 2006 Pontiac Solstice,(sold) 1966 MG Midget, 1987 Pontiac Fiero GT
Skeletor
Have thanks: 47 times
Postby gruff54 » Sun Dec 29, 2019 8:17 am
The main disadvantage I see to welding would be if they needed to be removed for some reason. If bolting, a spacer may need to be used to prevent the frame from collapsing, though I suppose you could use a square u-bolt of some sort. If I were to install sliders, I think I would weld a 1/4" plate (the appx height of the frame and about that length) to the frame, then weld the sliders to that plate. The plate would spread the load over a larger area of the frame than just welding the slider directly to the frame. As far as removal, if I can weld 'em on I better be able to cut 'em off! :lol:
Mike
'88 Trooper 2.6L 5 spd
'89 Trooper 2.6L 5 spd
gruff54
Has thanked: 44 times
Have thanks: 85 times
Postby Shawn Anthony » Tue Apr 27, 2021 3:49 am
Weld...ALWAYS weld.
Bolted on sliders shift around, wallow out bolt holes, sheer off bolts and they can make seriously annoying creaking sounds.
ALWAYS weld with backing plates and double gussets. Weld at a minimum of 3 locations 4 is better. Welding one slider mount to the long forward body mount will provide lateral support and rigidity to the sliders. thus securing the forward and back movement in extreme heavy loads, which is very very important.
Shawn Anthony
Has a Trail Truck
Have thanks: 32 times
Postby Shawn Anthony » Tue Apr 27, 2021 4:11 am
Shawn Anthony
Has a Trail Truck
Postby Enemigo » Tue Apr 27, 2021 11:49 am
What a timely bump of this thread. I just started my slider build last night. I used to be in the bolt on camp, until I realize how much work it was going to be compared to just welding them on. I basically came to the conclusion to weld on plates, then gusset the top, if I can, and I'll have the opportunity to clean up the frame a little at the same time. The most difficult part will hopefully be relocating my vacuum accumulator.
1999 Amigo - Sold
1999 Trooper. Mods TBD
Enemigo
Has thanked: 4 times
Have thanks: 30 times
Postby rogerryan » Wed Apr 28, 2021 4:53 pm
But bolting is the easy way in front of welding
rogerryan
Postby Enemigo » Wed Apr 28, 2021 4:59 pm
I don't know. I can put in welds easier than drilling holes.
1999 Amigo - Sold
Enemigo
Postby gruff54 » Wed Apr 28, 2021 8:18 pm
Enemigo wrote:I don't know. I can put in welds easier than drilling holes.
Me, too. Main advantage to bolting is you could remove it easier than you could remove one that was welded on. Also, I like Shawn's suggestion to weld to the body mount for lateral support.
Mike
gruff54
Postby Enemigo » Wed Apr 28, 2021 8:23 pm
None of my body mounts are oriented in a way where that would be easy. However, one of them is definitely bent. I'll have to knock it back out and gusset that mount. So, if you do weld to a mount, I'd consider welding a gusset across the opening as well. Make sure you can still access the mount bolt though.
1999 Amigo - Sold
Enemigo
Users browsing this forum: Guitarbuilder and 14 guests
