My 2002 Rodeo (V6 engine) has about 162K miles. I replaced the front brake pads and rear brake shoes and wheel cylinders a little over two years ago. I also flushed the entire brake system with fresh brake fluid. The fluid level in the brake cylinder reservoir has only dropped slightly, which I attribute to wear on the pads and shoes. The brakes feel solid although my wife and I both drive conservatively.
About a year or so ago, the ABS warning light started coming on sporadically. It usually went out during the next starting cycle. Recently, it has been on every time I drive the car. No other warning lights are on and the brakes still feel solid although I have not tried them on a hard stop.
Any suggestions or insight would be greatly appreciated.
Thanks,
David
Thanks,
David
