Wansink says that the average person makes well over 200 decisions about food Starbucks Grande caffe latte 16 116 increase profits at all costs. That means you always wind
cook over medium heat for about 10 minutes, or until tender, stirring occasionally to U.S. Units Canadian Metric Australian Metric if your cholesterol is 199 or lower 0
quences encoding only a single epitope repeat. In this way, it became clear that residues) and much less phosphorylated
it was just brought to my attention that a brother of ours passed away lastnight Mike Gres was hit by a car while jogging at Incarnate Word today Please say a prayer for him and his family and that
Let me also get opinions on where to put the Seafoam. That's what I'm really after. Alot have said that the brake booster line is best. Looking at the engine though, the PCV line looks like it makes the most sense. It connects to the common chamber right at the output of the throttle body. I would think that anything put in here would be evenly distributed to all injectors. The vacuum booster line (if this is indeed the brake booster line) connects over in a corner of the common chamber directly into one specific injector port (the rear-most port). Doesn't seem like that would be as good as the PCV line.
ph
Does nobody know where the brake booster line is or if it is indeed the same thing as the vacuum booster line? I thought this was kind of a simple question that I'd get a quick answer to.
ph
First, find the vacuum line that runs off the brake booster (it is the big round thing behind the master cylinder) and follow it to where it plugs in. On my Amigo it is right next to the EGR valve.
I have only run Sea Foam through this line, and it works great. Once you drive it, it looks like a mosquito sprayer truck. Using it in the oil before it is changed has almost eliminated my oil consumption problem too. It is great stuff.
Why not use both? Half in the brake booster line and the other half in the PCV? Couldn't hurt - right?
-- Shon
