problem is I have no back door :lol:outofrshell said:If you need the top left hinge, the bottom right hinge @ the back door is the same one. Usually the back doors are not worn as bad as the front. If the hinge is popping it is usually the pin gets bent and you can straighten them with a press not much you can do about sagging. DAVE
So does that mean the opposite is true ?outofrshell said:If you need the top left hinge, the bottom right hinge @ the back door is the same one. Usually the back doors are not worn as bad as the front. If the hinge is popping it is usually the pin gets bent and you can straighten them with a press not much you can do about sagging. DAVE
Well, if you'll stop being so defiant about it, let's find out whether the hinges on trooper doors will work on yours.Metal88 said:problem is I have no back door :lol:
but Ill defiantly keep that in mind tho!
No kidding! Didn't know that.outofrshell said:Yes lower back door hinge on left is the same as upper on right front door. Here is another tip it is easier to pull the front fender to change the hinge at the top about 10 small bolts and the fender is off don't even have to mess with the park light. DAVE
