Will the gas tank on a 1999 isuzu trooper fit a 1990 isuzu trooper?
Car manufactures will give different part numbers for the identical part when crossing different model years/generations or even models themselves. Ever see a 99 VX dash? its a 95.5-97 rodeo dash but in black. same part, different color and different part number. i had a 96 Passport with a black dash and black leather....never seen one since, that dash was used in a different model and year. 81-87 pup parts fit the troopers also and may have different part numbers. . Anyway, with Emission hose routing or different vapor/roll over valves locations on the top, there may be subtle changes to tank and cause to have a different part number because a 90 tank wont have the emissions piping the 99 has, yet the tank, itself, may be made from the same die, for the housing only...it would be interesting to see if they did, in fact, physically interchange as far as mounting goes....The part numbers don't cross reference. I checked on isuzupartscenter.com and they showed it as clearly different tanks
Holy cow lowzone! you just rocked my world with the VX vs. older Rodeo dash. I've seen both so many times but never made the connectionCar manufactures will give different part numbers for the identical part when crossing different model years/generations or even models themselves. Ever see a 99 VX dash? its a 95.5-97 rodeo dash but in black. same part, different color and different part number. i had a 96 Passport with a black dash and black leather....never seen one since, that dash was used in a different model and year. 81-87 pup parts fit the troopers also and may have different part numbers. . Anyway, with Emission hose routing or different vapor/roll over valves locations on the top, there may be subtle changes to tank and cause to have a different part number because a 90 tank wont have the emissions piping the 99 has, yet the tank, itself, may be made from the same die, for the housing only...it would be interesting to see if they did, in fact, physically interchange as far as mounting goes....
