when i have the heater set to defrost, or defrost and floor, their is a (getting louder) whine coming from under the truck, which is audible only from outside. when i switch the selector to blow out the dash or only the floor or both, it stops.
this happens both in recycling air and taking it from the outside.
:shock: what is it and is it an easy fix?
Your A/C compressor cycles on and off when in any defrost setting. Make sure your compressor isn't siezed and that there is enough oil/refridgerant in it.
I have a 92 Rodeo that is doing the same thing. (except that sometimes I can hear it from inside the truck)
I haven't checked the ac system since I bought it but I never use air conditioning. If it's something simple like refrigerant I'll fill it, but I don't want to buy a new compressor for a system I never use.
Can I disconnect the A/C completely? How would I do it? Any negative consequences?
Sounds like the A/C compressor is failing. When it locks up, you will get a massive squeal, followed by a battery light and loss of power steering when the sepentine belt breaks. Better start shopping for a compressor.
Regards,
Tom
