1 - 20 of 34 Posts
· Registered
Hi All,
I have a 1994 4x4 Trooper and its time for a clutch job. So, I ordered in advance an Sachs K70107-01. Rockauto says its the right clutch for this transmission (I also see it referenced all over the place too). Fast forward to yesterday, I yanked the trans out and its a totally different clutch, which isn't even on the service manual! Its an Exedy ISC 600. I cant even cross reference anything to the ISC 600. I cant even get an ISC 600 clutch kit (it appears).
My question to you all is; can somebody point me to the right clutch for this transmission?
This is the Sachs that is listed on rockauto and generally referred to in the work manual for the MUA:
Automotive tire Light Rim Bicycle part Automotive wheel system
This is the Exedy ISC 600 that I pulled out of the transmission:
Automotive tire Tread Rim Wood Wheel
· Super Moderator
98 Rodeo, 4JB1-TC
Ive got the diesel, a 4JG2 and its a 1994.
As I recall there are two different sizes. What difference are you encountering, diameter?
· Registered
Discussion Starter · #5 · (Edited)
On the sachs the clutch fingers point inward and has the locking collar, and the exedy clutch fingers point outward and does not have a locking collar. I 'think' the diameter is correct. These pressure plate assembles are totally different.
· Registered
Sachs K70107-01 is the wrong clutch. Most parts stores have the wrong listing.
LUK 626 1655 60 is the correct clutch set.
Edit:. I thought I had listed this other option too. Looking back I see I had forgotten to.
This clutch will also work; South Bend K09021-HD
· Super Moderator
98 Rodeo, 4JB1-TC
None of the diesels use a pull type clutch. Te clutch you ordered is for a gas engine.
· Super Moderator
98 Rodeo, 4JB1-TC
Don't know if I'm missing something, but from what I can see, that PN is also for a gas powered vehicle not a diesel.
· Super Moderator
98 Rodeo, 4JB1-TC
As I stated above
"most parts store have the listing wrong"
I would go as far to say that 99% of parts stores have the wrong part listed in their catalogs.
These 2 clutches I keep these in stock just for this reason.
You stated that the Sachs number is wrong, not that the LUK number you provided has the wrong application info.
Are you saying that the part number you provided is correct for a diesel, and that the application info is incorrect?
· Registered
Ive successfully used a rodeo clutch for the v6 in my MUA 4jb1T trooper. That being said, it would be cheaper to get your clutch disc rebuilt than to source a new kit. Post measurements of what you pulled out and ill see if i can find anything. Looks like the parts thread over on 4x4wire was lost when the forum went down.
· Super Moderator
98 Rodeo, 4JB1-TC
Rectangle Font Parallel Number Screenshot
Rectangle Font Parallel Number Circle
· Registered
@bellavesus What did you do to make that clutch work?
· Registered
From the photo of the Exedy clutch that you removed it appears that the clutch disk is worn to the rivets. If this is true you will need to inspect the pressure plate and flywheel for reuse. If they are both damage due to extra machining cost (or replacement cost, depending on the amount of damage) rebuilding the clutch plate would not be cheaper than a full clutch kit & a flywheel.
I have 2 clutch sets that will fit your vehicle if you are interested in purchasing them. In stock I have the LUK 626 1655 60 & South Bend K09021-HD. Both clutches are great quality.. The LUK is an equivalent to OEM clutch and is my go to set. The south bend is a much more stout clutch than the original. If you tow trailers, haul cargo or enjoy serous off roadding the South Bend is the better choice.
· Registered
@Shawn Anthony Yes indeed, that clutch disk is toast. That isnt getting reused, and its equally as blasted as the throwout bearing and the pilot bearing. My flywheel is getting surfaced as I type. I am interested in that clutch that you have. Shoot me a DM and lets talk a little about pricing.
· Super Moderator
98 Rodeo, 4JB1-TC
Beware of the info Shawn insists on, It does not match the info for the clutch that you have removed. Make SURE you verify before purchasing, as all my resources indicate it is incorrect for you vehicle.
· Registered
Discussion Starter · #18 ·
@mudoilngears Thanks for the warning on that, I can cross reference the ISC 600 measurements vs. the the LUK clutch that Shawn has.
· Super Moderator
98 Rodeo, 4JB1-TC
ISC is the number for just the cover, the screenshots I posted above have the info for the disc, which you can verify against the old disk. You may be able to find the PN on it, although Exedy uses a rather pale etching which is easily obscured.
1 - 20 of 34 Posts
